12-04-2004, 14:24 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: www.microera.si
Member: 4923 Status: Offline Thanks Meter: 74 | 535 I want connect with original cable connected to RS232 but gsm will allways power ON, then I get this message! ------------------------------ Ready... Waiting for ignition... Loading boot... ERROR 0033-4E (Phone not respond, check cable) ------------------------------ what is wrong? p.s. I'm cleaning contacts but it's the same! |
12-13-2004, 14:45 | #5 (permalink) |
Member: 4923 Status: Offline Thanks Meter: 74 | >why you said its impossible open your cable? because it's in one piece! I'm cut cable (3 wires) and inspect that is: 1 wire for GND and another two wires wired to TX! RX is unconnected! factory failure I'm get new cable...... |
12-15-2004, 18:41 | #7 (permalink) |
Member: 4923 Status: Offline Thanks Meter: 74 | I make cable....and work! Philips cable pinouts: http://www.microera-sp.si/Philips_cable350_lres.jpeg Best regards |
Unlock my 535 | msw | BF, BG, TH, BHx Series | 6 | 11-21-2003 03:50 |
Alcatel 535 Java | jhudhas | BF, BG, TH, BHx Series | 0 | 11-17-2003 15:23 |
Alcatel 535 unlock code? | unicos | Phone Unlocking Codes & Maps | 0 | 11-13-2003 15:21 |
Cables for Siemens ST55, Alcatel 320 & 535 needed.... | FractalizeR | Wanted Products | 6 | 10-20-2003 07:42 |
soft for alcatel 320 535 | alex3 | Wanted Products | 3 | 08-10-2003 20:52 |
