Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Martech products > Martech Phones / Modems Tools > SIEM Service Tools
Old 02-07-2007, 18:15   #1 (permalink)
kimo59's Avatar
Member: 183437
Help for benq-siemens el71 unlocking !
Please i need any tips to make easy el71 unlocking, i use usually a thin wire but very difficult to unlock, one time i spent 4 hours to unlock it, very hard, if anyone get some idea to suggest it may help all of us
B.R
.: Kimo59 :.
Old 03-05-2007, 12:23   #2 (permalink)
.:Rici:.'s Avatar
Member: 46817
Select in Martech normale mode lower baudrate and this testpoint conect it to gnd an unlock I use read codes four me work
You must use a needle noth this tespoints from Testpoint adapder
Old 03-08-2007, 21:14   #3 (permalink)
fingusio's Avatar
Member: 16927
Sonork: 100.1592866
You are certain ? somewhere i read that with this TP we can burn TP adapter.
Someone else can confirm this?
br,
fingusio
Old 03-08-2007, 22:01   #4 (permalink)
.:Rici:.'s Avatar
Member: 46817
First for this metod you dont need testpoint adapter just plug cable only in box select normal mode for batery I use power supply and go
Tested on 5 phons with read code and all ok and unlocked
Mungos
Old 03-10-2007, 12:30   #5 (permalink)
kimo59's Avatar
Member: 183437
Tested, not worked for me, if you can give us correct procedure please, you use only pcb with extern alim, but when you have to "clic auto-ignition button", you connected before keypad to pcb or you push on black button on service cable ???
Old 03-10-2007, 13:28   #6 (permalink)
.:Rici:.'s Avatar
Member: 46817
- Conect only box no testpoint adapter you dont need him
Select Normal Mode
- plug cable in box and conect cable with phone
- change baudrate to 115200 and chek use slow unlock/reperir metod
- conect power supply to batery way
- make testpoint with needle and hold him
- press read phone and when on the program you see "Louding main Boot"
disconect testpoint and phone is reading
- then make unlock I use read code or laiter you can make manual bothcore pass and use direct mode you have all in log file
Tested on 5 phones and for me work
Mungos
The Following User Says Thank You to .:Rici:. For This Useful Post:
Old 03-10-2007, 15:12   #7 (permalink)
kimo59's Avatar
Member: 183437
Ok, thanks i understand so when you clic "read phone" or "unlock" it ask you to "press ignition mode button for short time" i want to know what you do exactly ??
i have to push power button on phone ??
Old 03-10-2007, 17:04   #8 (permalink)
.:Rici:.'s Avatar
Member: 46817
No hi do alone ignition when you press read phone you must use normali cable for Martech
Old 03-20-2007, 16:34   #9 (permalink)
rico1's Avatar
Member: 5397
Mungos!
Thanks shared information! ;-)
br
rico
Old 03-20-2007, 16:52   #10 (permalink)
fingusio's Avatar
Member: 16927
Sonork: 100.1592866
@rico1
Did you try this TP? Working?
br,
fingusio
Old 03-22-2007, 11:54   #11 (permalink)
..::alexis::..'s Avatar
Member: 289200
Originally Posted by fingusio View Post
@rico1
br,
fingusio
yes- this tp work fine!!!
Old 03-22-2007, 12:07   #12 (permalink)
.:Rici:.'s Avatar
Member: 46817
will Martech make this TP solution on Testpoint Adapter it will be fine in next update
Old 03-23-2007, 11:51   #13 (permalink)
Member: 3811
Good work @Mungos this test point work your instructions are 100% bravo
Old 04-10-2007, 11:02   #14 (permalink)
Member: 267787
Can i unlock EL71 phone infinity box or other free softwere
Old 04-10-2007, 11:04   #15 (permalink)
Member: 267787
EL 71 unlock
can i unlock benq siemen EL71 with mxkey asif_ae MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-21-2010 14:14
BenQ-siemens EL71 success unlocking by dreambox jakoy DreamBox 0 07-14-2008 12:29
Benq Siemens El71 Orange Locked : Unlocked At Last cetech Martech CLIP / Box / Key 0 06-05-2008 11:06
how to unlock benq siemens EL71 mohamedrimas DreamBox 2 05-16-2008 14:37
El71 Benq-siemens Successfully Unlocked Via Martech.... clearcom Martech CLIP / Box / Key 0 10-09-2007 08:18
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.36107 seconds with 9 queries
