Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Martech Products > Martech Phones / Modems Tools > SIEM Service Tools
Old 12-22-2007, 13:19   #1 (permalink)
moni108's Avatar
Member: 26440
Thanks Meter: 6
sl75 phonecode locked need help pls
hi, can this be unlocked without use of testpoint. thanks
Old 12-22-2007, 20:58   #2 (permalink)
Member: 337837
Thanks Meter: 536
WHICH CODE YOU WANT TO REMOVE USER OR NETWORK
Old 12-23-2007, 11:52   #3 (permalink)
..::alexis::..'s Avatar
Member: 289200
Thanks Meter: 219
just use UNLOCK or Read codes by DIRECT MODE.
he write- user code. So 1. please before reading.
2. It' s don't matter what code- you can clear all code using MARTECH.
Old 12-23-2007, 15:11   #4 (permalink)
moni108's Avatar
Member: 26440
Thanks Meter: 6
thanks 4 ur reply, when i select direct mode , it tells me it will overite the original boot area is that ok to do?
Old 12-23-2007, 16:36   #5 (permalink)
Member: 289200
Thanks Meter: 219
yes.
when ask select YES(overwrite original BootCore)
Old 12-23-2007, 17:29   #6 (permalink)
moni108's Avatar
Member: 26440
Thanks Meter: 6
yes.
thank you very much.
one last question.
can this method be applied to all supported fones by martech box.
Old 12-23-2007, 22:14   #7 (permalink)
Member: 289200
Thanks Meter: 219
one last question.
by DIRECT MODE without opening only for S-Gold which are supported by DIRECT MODE(formatting BootCore) or with java midlet.
For other you must open the phone.
k770i cid53 4 lock closed help pls. karina23b Cruiser Suite 4 11-16-2009 09:26
GD55 Phonecode Locked -- Please Help fym Panasonic 5 09-02-2007 13:22
N105 network locked need help billgate VLSI, Conexant, Skyworks and Old Models 13 05-22-2004 21:41
5110 v5.30 locked NEED HELP! Victim Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-26-2001 06:22
Page generated in 0.33688 seconds with 8 queries
