12-12-2005, 09:56 | #2 (permalink) |
Junior Member Join Date: Nov 2005
Member: 204327 Status: Offline Thanks Meter: 0 | I had this error, however when i deleted the old verision of the TMS client (both the new and old versions were in the same folder) and re-started my PC it didn't happen any more. |
12-12-2005, 14:12 | #3 (permalink) |
Freak Poster Join Date: May 2004 Location: Denmark
Member: 64783 Status: Offline Thanks Meter: 5 | It has started appearing for me aswell! Saw it first time in v1.96! .. also in 97 and 98.. also experiensed it in my admin system :/ Needs a restart and then it is gone. |
12-22-2005, 19:20 | #5 (permalink) | |
Junior Member Join Date: Dec 2005
Member: 207526 Status: Offline Thanks Meter: 0 | Quote:
12-22-2005, 19:57 | #6 (permalink) | |
Product Supporter Join Date: Aug 2002 Location: Movitel.NET
Member: 14284 Status: Offline Thanks Meter: 17 | Quote:
This is not the same problem. This problem is very clear, you must to log on Windows using administrator rights account... User, Super User and Normal user are not valid accounts for the first time you run this software. Regards, | |
12-22-2005, 20:40 | #8 (permalink) | |
This seems to be a Sharp3G solution, right? :-) Regards, | |
12-22-2005, 22:49 | #9 (permalink) | |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | Quote:
wbr Siroya | |
12-23-2005, 07:43 | #11 (permalink) | |
12-24-2005, 02:36 | #12 (permalink) | |
which client version are u using? Use 2.01 and report results Regards, | |
12-25-2005, 02:14 | #13 (permalink) | |
12-26-2005, 01:39 | #14 (permalink) |
Member: 199856 Status: Offline Thanks Meter: 0 | I am having the same problem, cannot run TMS 2.01 under WinXP. You are getting this error because TMS is already running in the background, not sure why it doesn't show its front end, but when you try running it again, it complains because its driver (oreans32) is already loaded and cannot be re-created again. Don't know if my WinXP has a problem, but TMS version 2.0 runs OK. To try again, just kill the TMS process (i.e. client.exe) and start it again, in my case the process starts and keeps eating RAM, 20K at a time and its allocated RAM keeps growing. Please someone from TMS team explain this, is there a special setup for WinXP. I downloaded the TMS 2.01 directly from movitel and also via the 'info' link in TMS itself, both ways I get file (v2.01) that behaves the same (no FE). Cheers and merry Xmas |
12-26-2005, 11:49 | #15 (permalink) | |
we have prepared some fix for you guys :-) please download www.movitel.net/ftp/tmsfix.zip, unzip files, read the TXT file and follow the simple and easy steps. after all please report results and feedback, we are waiting :-) Regards, | |
error when open de box | sanpintor | VygisToolbox | 6 | 03-18-2010 15:39 |
error when open ub. | wasifkhan | Universalbox | 13 | 08-23-2009 20:52 |
protection card error when opening LGI_132SC | MC Harami | VygisToolbox | 4 | 06-13-2008 19:22 |
2.7 error when open soft | mbarek_oussema | HWK | 2 | 05-24-2008 17:29 |
error when open new 8.10 | gerhardt | Cruiser Suite | 1 | 01-24-2006 13:58 |
