08-09-2005, 01:10 | #3 (permalink) | |
Product Supporter Join Date: Aug 2002 Location: Movitel.NET
Member: 14284 Status: Offline Thanks Meter: 17 | Quote:
just install your cable drivers and select the virtual comport in the available comports list and mark DTR and RTS checkboxes. browse and load flashfiles and press flash Regards, | |
08-16-2005, 22:31 | #4 (permalink) |
No Life Poster Join Date: Oct 2000 Location: Split / Zagreb, Croatia Age: 53
Member: 2236 Status: Offline Thanks Meter: 58 | Hi Murph... I have original DCU60 cable and chinese copy of that cable... does not mather which cable I connect to USB, XP does not ask for any drivers for that cable so at the moment I can't unlock K or D 750 When any cable is connected, I start the software and select unlock and then must press C and connect cable but phone turns on... battery is full... Any solution P.S.: some cash coming to you in some days |
08-16-2005, 23:25 | #6 (permalink) | |
Freak Poster Join Date: Jun 2005 Age: 54
Member: 155549 Status: Offline Thanks Meter: 1 | Quote:
Btw. just the flashing is what works with current TMS client, unlock not yet if do you use DCU-60 cable. For unlock you've to use TMS or Cruiser cables. | |
08-16-2005, 23:44 | #7 (permalink) | |
Member: 2236 Status: Offline Thanks Meter: 58 | Quote:
But what if I make a COM cable... will flashing and unlocking work as well or not... Legija, PM on the way to you... | |
DB2020 cid52 flash ic unlock solution guide | Gozha | Sony Ericsson | 18 | 03-04-2008 15:10 |
K750 unlock sw and Flash file | simlockman1 | Cruiser Suite | 5 | 09-21-2007 16:34 |
E700 Flashing Guide ? | sheepy | SYSOL Platform | 21 | 05-04-2006 13:11 |
Free SMSc's and Flashing Guides | davieb | GSM Mobile Links | 0 | 12-05-2001 15:51 |
