Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > TOTAL MultiServer
Old 09-09-2005, 21:42   #1 (permalink)
Member: 179076
k750i > w800 error when installing language
as title said i get an error that says my battery is low.. thats complete bs since i checked it in my mates k750i also used his battery but still the same.
any hints greatly appreciated !
Old 09-09-2005, 22:13   #2 (permalink)
Member: 14284
Hi there,
which cable are using? client version? screenshot?
btw... at which procedure does it stop? always same % ?
Regards,
Old 09-09-2005, 22:37   #3 (permalink)
Member: 179076
not always the same % mostly around 10-15 even got almost full bar once :P ; im using the multiserver cable with the black box on it. client version 1.83 of TMS.
firmware: W800i_R1K001_ZONE_1_EU-EMEA-US.75S
language default : W800i_R1K001_EU4_EN_DA_SV_NO_FI_IC.75D
Have i missed something when i set the whole thing up?
I've used all the different baudrates aswell...
got windows xp sp2 with 64bit processor.
Old 09-09-2005, 23:24   #4 (permalink)
Member: 155549
You've a phone with crap hardware if your battery and cable is 100% ok.
What's the result if you try flash Delfang file with firmware file together?
Old 09-10-2005, 08:41   #5 (permalink)
Member: 179076
same result, firmware flash is ok. but when it begins on the language file. same thing happens..
Old 09-10-2005, 12:21   #6 (permalink)
Member: 155549
Reflash firmware part with a K750 red firmware with Cruiser or TMS cable.
Then try flash K750 red flashes via DCU-60 cable! Result? Stops with DCU-60 cable too at deflang flashing?
How come I get this error when installing applications? Sgt_Strider HTC & Smartphones ( WM Without Touch) 10 10-04-2007 08:48
Error when install itunes for L7. Helpp meee!!!! zicusa P2k Series 0 10-18-2006 08:31
k750i > w800 r1bc002 - TMobile US - dreadfully slow GPRS joecarter30 Sony Ericsson 1 07-04-2006 21:29
how to flash k750i -> w800??? .:GSM International:. SonyEricsson (USB-Smart) 3 10-21-2005 20:59
Error when installing extra cables using Pro version under XP AlexG Cruiser Suite 12 06-15-2004 05:46
Page generated in 0.26008 seconds with 12 queries
