08-09-2005, 15:00 | #1 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 137814 Status: Offline Sonork: 113690 Thanks Meter: 3 | TMS 2 in 1 Cable Witch USB Driver? I can't locate which USB driver to install to get this cable to work. Can anybody please direct me to the right one and possibly post it here? I've tryed the K750CableDrivers, USBtocom and the UC10 driver. I get errormessage: The hardware was not installed because the wizard cannot find the necessary software. I'm running TMS v 1.80 What do i need to do to get this cable working?? All help is greatly aprisiated Thx in advanse |
08-09-2005, 17:26 | #3 (permalink) |
Member: 137814 Status: Offline Sonork: 113690 Thanks Meter: 3 | I have installed them and they are the right one for 2 in 1 USB TotalMultiServer Cables. New problem though. I'm trying to Read Cid/Test Cable and all that is happening is a message to press phone on button. I do it, and then nothing. I've choosen the right com port and have tryed all speeds. Any idea of what to do? BR Kooolkat357 |
08-09-2005, 17:42 | #4 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 54
Member: 155549 Status: Offline Thanks Meter: 1 | 1. switch off the phone 2. remove the cable from the phone 3. be sure that DTR RTS checkboxes checked. 4. Push Read Cid/Test cable 5. Connect the Cable to the phone Do always in this sequence. |
08-09-2005, 17:59 | #6 (permalink) | |
Member: 137814 Status: Offline Sonork: 113690 Thanks Meter: 3 | Quote:
Dumb question maby, do i use the same seguense for unlock, debransing and K750i to W800i flashing? | |
08-09-2005, 18:02 | #7 (permalink) | |
Member: 155549 Status: Offline Thanks Meter: 1 | Quote:
Yes. Press first button (Do Jobs, Flash etc.) on the program and just after this connect the switched off phone to the cable. (And no need press power button procedure starts without it) | |
08-09-2005, 18:11 | #8 (permalink) | |
Thank you!! Thank you!! Thank You!! This will make my life much easier!! Nice there's so helpeful people around.... BR Kooolkat357 | |
iPmart BX Series 2 in 1 Cable Compatible For Blackberry | IPMART | ipmart WebShop | 0 | 01-11-2010 07:00 |
Need E210 Rj+usb 2 in one cable pinout | umadineshdas | UST Pro II | 1 | 08-02-2009 11:22 |
Samsung Z630 unlock problem = 2 in 1 cable problem or.. | radez | Z3X-Team Products | 10 | 08-27-2008 22:19 |
2 in 1 cable haierd1600+sam n109 | LAL GUPTA | Various CDMA/TDMA Cell Phones | 2 | 07-04-2007 18:15 |
