11-25-2004, 10:51 | #1 (permalink) |
Junior Member Join Date: Nov 2004 Age: 51
Member: 93772 Status: Offline Thanks Meter: 0 | Using a proxy server with Total Multiserver I am trying to decustmize a K700i using Total MultiServer, however, my internet connection is via a proxy server. How do you configure Total MultiServer to use a proxy server? Cheers Hanley |
11-25-2004, 11:41 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | You can't, at least from my playing with Multi. There's a couple of programs available that can trick a program into using a socks5 server (when it thinks it's a native connection), but that's about it. Certainly I know of no easy way to use a normal http proxy server. You could look at tunnelling etc, but then you're getting rather tricky and kinda outside the scope of this forum (too hard to explain) |
11-30-2004, 05:57 | #3 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Seattle, WA USA Age: 43
Member: 47173 Status: Offline Thanks Meter: 3 | i don't think those programs work on total server. I use sockscap on a regular basis, and whenever I try to start total server under sockscap, my computer goes all crazy and eventually locks up (stops allowing file read/write apparently). So, looks like you're out of luck. |
11-30-2004, 06:28 | #4 (permalink) | |
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
K608i with Total MultiServer | L19YDC | TOTAL MultiServer | 2 | 12-21-2005 20:16 |
Sharp 903SH with Total MultiServer | yueyo | TOTAL MultiServer | 20 | 11-20-2005 22:10 |
k608i with Total Multiserver Flashing Problem | shuttle4 | TOTAL MultiServer | 2 | 11-01-2005 05:18 |
Dead k700i after flashing with Total Multiserver | devilfysh | Sony Ericsson | 2 | 03-01-2005 13:17 |
Need help with unlock k700i and t610 new version with total multiserver! | mobile_2003 | TOTAL MultiServer | 4 | 10-21-2004 13:57 |
