Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > TOTAL MultiServer
Old 11-30-2005, 15:04   #1 (permalink)
Member: 204327
z520i firmware flash: Configuration error
I succesfully unlocked my pay as you go (from 02) z520i but it all went t!ts up when i tried to flash the firmware.
Ive flashed other S/E handsets using this software with no problem before however this time, the software got to the 'GDFS' part of the process and then cut out. There was no error number, just a message telling me to email the JPG and ATS file to the given email address. Ive done this of course, but was wondering if anyone on here had any tips they could give! PS: the ATS file was in excess of 40mb, is this right?
Now when i start the phone without a SIM i get the 'Insert Sim message' however on placing a SIM into the phone i get the configuration errror message!
Old 12-07-2005, 18:04   #2 (permalink)
Member: 52338
this means that your flash is incomplete (obviously)
you'll have to contract your reseller and send them the screenshot (since ur ats file is 40MB, not very realistic to email it)
most of us are good about refunding credits in this case (if you have a screenshot) then we can email murphy and get the credit back that we gave you as a replacement.
just make sure your battery is fully charged. You'll need to use another phone or a desktop charger to charge the phone now since it's firmware is incomplete it wont take a charge.
remove the battery and replace it before you start another operation, all should go well
good luck!
--Corey
Old 12-08-2005, 10:29   #3 (permalink)
Member: 204327
Hello, thanks for your response. I never actually lost the credit, when the flash process failed i checked my account and the credit was still there. Should i just try flashing again (with a full charge) or is there something else that could be wrong?
Old 12-08-2005, 18:00   #4 (permalink)
Member: 52338
just try again.
Yes make sure that battery is FULLY charged, this is very important especially for flashing.
'm glad to hear your credit was not used. that's always annoying when the credit is used and the flash is incomplete.
Sincerely,
--Corey
Old 12-12-2005, 08:54   #5 (permalink)
Member: 204327
Hmmm, well i borrowed a z520i from a friend and a friend and chaged the battery this weekend however after attempting the flash the firmware again i'm still in the same position!! Would making a backup of the 'GDFS' from another z520 and then restoring it to my handset make any differenece?
Old 12-12-2005, 11:58   #6 (permalink)
Member: 155549
Which version of the client do you use? Try again with 1.98 it will work!
Old 12-12-2005, 12:04   #7 (permalink)
Member: 204327
I downloaded the new 1.98 over the weekend and tried the process using this, it just gave the same results as before.
Old 12-12-2005, 12:18   #8 (permalink)
Member: 155549
What cable do you try? DCU-60?
Old 12-12-2005, 12:20   #9 (permalink)
Member: 155549
ps.: and try the latest flashes also, R3C035 or something like this...
Old 12-12-2005, 12:26   #10 (permalink)
Member: 204327
No not, the DCU-60, i got it from http://www.irwebonline.com/acatalog/...0i_Unlock.html
however it believe it is the total multiserver 4 in 1 cable shown here:
http://www.totalmultiserver.com/cable.htm
Old 12-12-2005, 12:41   #11 (permalink)
Member: 155549
Check your Private Messages!
Old 12-13-2005, 08:23   #12 (permalink)
Member: 204327
Well thanks for you help casinoman, i've sorted this problem out now by trying the process with the newer 'RED' firmware and language files in the 1.98 software. I had to perform a 'Repair/Recover Eprom' before it would accept the new language file. Handset seems to be working great now.
w550 Sony ericsson Mobile Error Configuration error Please Contact Your Network Oppe Ravi Potdar Sony Ericsson 11 02-04-2011 14:44
Z520i firmware in Z520a? Veritable Cruiser Suite 6 05-01-2008 08:38
Z520i firmware R3J017 needed. For repair!!! Invader Cruiser Suite 6 05-29-2006 10:34
Latest z520i firmware? Patrick Sony Ericsson 0 12-10-2005 12:07
configuration error on S710a after firmware flashing sofakingcool420 TOTAL MultiServer 2 10-11-2005 06:25
Page generated in 0.42378 seconds with 11 queries
