ANYCALL W5200 after unlock say Invalid card in this Region Code: Phone type selected : SPH-W5200 |
insert the sim card in Other phone and fill own number BR, Douhal |
detailed info needed thanx |
insert sim in motorola or in other phone :) 1 ) - go to phone book Menu 2 ) - select my nubmers 3 ) - and feel phone number of the SIM CARD ( inserted in the phone ) 4 ) - Post Result Now Please :) -------------------------------------- about Phone Unlock READ THIS : - if after connecting you see active button "Direct unlock",press it for phone unlocking - if you see active "Write backup" button,it means,that software creates lock zone backup,when unlocking goes,and later if something went wrong you can restore phone with this backup.For backup writing press "Write backup" and you will be redirected to folder,where your phone's backup is.All backups in name has IMEI and last digits of backup number has date and time,when backup was created. - if after connecting you see "Read unlock code" button active,it means,that for this model is supported unlock code reading.Please follow software's instuctions for code entering. - if you not see active "Direct unlock" button-please check at support sites if exists patched unlocked flash for your phone's model. If after unlock phone is still locked-flash phone with coresponding flash file from support sites and repeat unlock again.Some flashes are already unlocked-they have in name "u" - for example "SCH-W360_BB22u_EN_KOR" is unlocked flash and unlock is not needed after flashing. For W5200 at supports exists SPH-W5200_DA25u_EN_KOR flash file-it is unlocked flash file BR,Douhal |
only got unlocked After Flash Code: Connecting ... OK |
