Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 01-29-2006, 21:18   #1 (permalink)
Member: 198717
B2050 keeps powering up instead of going into boot for unlocking
Hi There,
I'm using my Vygis Unlocker with the LG 7050 cable, Every time I go to power it up to enter test mode, the phone keeps powering on.. I had a one off time luck but when it started to read it went something like parameter error, I've had simular problems with a C3300 but with a bit of persistance managed to get it unlocked.
Can someone advise me where I am going wrong and why this keeps powering on as its getting a tad annoying.
Cheers
Dean
Old 01-29-2006, 21:30   #2 (permalink)
blaiseid's Avatar
Member: 37735
Originally Posted by drancill
Hi There,
Cheers
Dean
1=Put Braudrate to 115200
2=Remove battery from Phone
3=connect phone to your cable and connect cable to box
4=Click CONNECT from Vygis
5=Insert Battery.
Should Boot.
If not, you can press Power Button .
Ready to work.
Old 01-29-2006, 21:45   #3 (permalink)
Member: 198717
Thanks,
Still no luck if I hit power it powers up, if I dont it does nothing.
Any other suggestions?
Thanks
Dean
Old 01-30-2006, 08:17   #4 (permalink)
blaiseid's Avatar
Member: 37735
Clean your phone port and cable connector.
Old 06-12-2006, 06:11   #5 (permalink)
Member: 225758
You can try this my friend...
After attaching phone to the box (vygis) and the phone turns on just power off the phone manually by pressing the power button untill it turns off. Click connect then press & hold the power button untill it finished booting.
Motorola's will not go into Boot Mode. barrieb P2k Series 1 03-17-2007 13:11
v980 fone will go into boot but will not power on coolmax P2k Series 1 03-15-2007 23:50
dead v980 won't go into boot defuct_k Smart-Clip 5 02-13-2006 21:23
moto v1050 wont go into boot mode tonypooley Smart-Clip 2 10-11-2005 10:10
C55 powered by power supply instead of battery Otik E-Gold Based Phones 2 11-10-2003 10:20
Page generated in 3.45023 seconds with 11 queries
