-   VygisToolbox (http://forum.gsmhosting.com/vbb/f282/)
-   -   BH3: Flash Type not supported (http://forum.gsmhosting.com/vbb/f282/bh3-flash-type-not-supported-209069/)
dannyogolo 05-27-2005 12:13
I have this BH3 phone which connects fine with Serial (com) cable, but when I connect using Toolbox with USB cable, I get this: Flash Type: 0008 Then a window pops up with message: Flash Type not supported.
I have switched the box to all directions and combinations, still same error.
I would have used serial cable, but I need to flash this phone, and my serial cable has some bad pins, and I always loose connection B4 flashing finishes.
But The toolbox cable pins are OK (its a new one)
Is there a solution for the box, so I can flash with it ?
Thanks in advance
Gobi 05-28-2005 07:43
- please check in the box if the small modification was made - like in the corrected.jpg picture on support area...
Also try to keep the phone battery lifted , from the contact, then connect the cable to phone , press ''Connect '' in the software and then only FAST press the battery in the phone ...
Else i don't see any reason why it should not work..
regards,
Gobi
Page generated in 0.13231 seconds with 5 queries
