10-06-2011, 05:38 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: N/A
Member: 109335 Status: Offline Thanks Meter: 27 | c310 issue but every time a change imei to original, or others, signal lost already factory defaults on soft and phone, used 3 of the 4 flashes available same result uart and usb same result but i was using LGI_1_92SD.exe now im trying with version 1_95SD any ideas? or tips? cause there are not that many options ok i used 95SD eeprom flash and after, i changed imeis, checked the phone imei s, changed ok, (without turning it of after flash and imeis), and signal great, but if i reset it or only turning it on/off, same again no signal????? network manual auto etc same result Connecting phone - connect USB cable to phone, phone must be OFF and without battery ... OK Opening USB Flash Port (COM21) ... OK ---------------------------------------------------------- Loading primary loader ... OK Loading secondary loader ... OK Loading certificate ... OK ---------------------------------------------------------- Reading phone info,please wait ... OK ---------------------------------------------------------- Reading flash ... OK Saving flash ... OK Flash saved to file : LG-C310_LGC310AT-00-V10a-MEA-XXX-NOV-30-2010+0_ _eep.crf ======== Process completed ======== Operation time - 0:00:01 Port USB - RS232 by Vygisoft disconnected Port USB - RS232 by Vygisoft connected ---------------------------------------------------------- Reading IMEI ... OK Phone IMEI A : 354035-04-......-. Phone IMEI B : 354035-04-......-. ======== Process completed ======== Operation time - 00:03 ---------------------------------------------------------- Writing IMEI ... OK ======== Process completed ======== Operation time - 00:08 ---------------------------------------------------------- Writing IMEI ... OK ======== Process completed ======== Operation time - 00:08 |
Problems with GD87 + security issues | BSE cybercow | Panasonic | 5 | 07-23-2003 19:09 |
Issues with flash and unlock on Motorola V66 | alturner2 | Motorola P2k | 0 | 05-22-2003 00:21 |
Issues of appearance | killa'MROZIN | x1x to x45/x50 | 1 | 05-13-2003 11:56 |
Nokia 7210 Unlocking issues | Flexus | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 02-13-2003 20:32 |
SL42 Upgrade Issues | d0g | x1x to x45/x50 | 1 | 04-23-2002 23:13 |
