07-24-2011, 12:43 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: HGJIKL
Member: 1360208 Status: Offline Thanks Meter: 133 | can,t unlock lg a100 with vygis,need help soon. Gw300 cables both tried with& with out battery But not conecting,please Share easy and tested method. |
07-24-2011, 23:20 | #2 (permalink) |
Freak Poster Join Date: May 2010 Location: my work Age: 54
Member: 1305009 Status: Offline Thanks Meter: 401 | For me too not working with & without battery.cable Work Perfecto for other models,gs101&gw300 both not working for Lg a100,is this method tested or released Just after one user report? |
07-25-2011, 08:46 | #3 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Mrocco
Member: 184161 Status: Offline Thanks Meter: 22 | Hi,it work perfecty with me : i used FS102 cable + Phone without battery + Read codes and of cours the last LGI_1_94SD When the soft gives you the code , power phone with a test sim and 2945*#100# then menu - security - sim unlock - network code and put the code Good Luck BR |
The Following User Says Thank You to Boukra For This Useful Post: |
07-25-2011, 08:53 | #4 (permalink) | |
Member: 1360208 Status: Offline Thanks Meter: 133 | Quote:
batteryofcourse using last LGI_1_94SD . | |
07-25-2011, 09:34 | #5 (permalink) |
Member: 184161 Status: Offline Thanks Meter: 22 | Yes , GS102 cable and at the first attempt the phone is connected!!! so please review your com port or phone connector and software instructions Hope that you success Good like BR |
07-27-2011, 21:34 | #7 (permalink) |
Freak Poster Join Date: Mar 2010 Location: UK
Member: 1255356 Status: Offline Sonork: 100.1607364 Thanks Meter: 129 | hello vygis team .... hello vygis team and all members of gsm forum i have got problem with vygis tool . when i open vygis shall it gives me error : THERE ARE MORE THAN 13 FOLDERS ON GYGIS SHELL, PLEASE BE SHURE THERE IS NOT DUPLICATED FOLDERS OR WRONG FOLDERS ON VYGIS SHELL . I TRIED EVERYTHING NO LUCK .. SO I GIVE UP PLZZZ HELP ME THANXXXXX IN ADVANCE |
02-28-2014, 20:28 | #8 (permalink) |
Junior Member Join Date: Feb 2012
Member: 1720836 Status: Offline Thanks Meter: 3 | in comport select FT232R USB UART hit connect port hit connect phone connect phone with GS102 uart cable without battery vygis have 2 ports, USB and COM1 but u have to connect uart cabel in USB port its simple with this method i have repaired imei of LG A100 with VYGIS BOX |
04-03-2014, 15:02 | #9 (permalink) |
No Life Poster Join Date: Jan 2009 Location: SPAIN
Member: 938547 Status: Offline Sonork: 100.1591926 Thanks Meter: 481 | Connect RJ45 cable to phone, phone must be without battery ... OK ---------------------------------------------------------- Loading primary loader ... OK Loading secondary loader ... OK Loading certificate ... OK ---------------------------------------------------------- Reading phone info ... OK ---------------------------------------------------------- Unlocking ... Making backup file : Reading eeprom area ... OK Saving flash ... OK Backup saved to file : LG-A100GO__356861044503030_bkp.crf Writing eeprom area ... Erasing flash ... OK Continue writing flash ... OK ======== Process completed ======== Operation time - 00:03 |
04-03-2014, 15:03 | #10 (permalink) |
Member: 938547 Status: Offline Sonork: 100.1591926 Thanks Meter: 481 | use infinity box as interface + rj45 gs10x/gs102 cable with vygis box com you cant connect it i dont know why but this is impossible to get it connected |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
