Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 05-30-2009, 21:06   #1 (permalink)
Member: 310155
Thanks Meter: 1,313
cant repair U890 !!! only show yellow screen
Hi,
If i on with its emergency mode(2+5) dn its show only "3"
but if i on its normal mode, dn its show only 2 second "file system startup please wait" dn only show yellow screen.
so i cant flash ist file system.
need help plz..........
The Following 2 Users Say Thank You to reaz.com For This Useful Post:
Old 05-30-2009, 21:47   #2 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
Thanks Meter: 793
change firmware to auther or chage change contry
Old 05-30-2009, 22:16   #3 (permalink)
Member: 411207
Thanks Meter: 164
use furious it's very eazy and repatr u890 very good
Old 05-30-2009, 23:06   #4 (permalink)
Member: 4458
Thanks Meter: 25,853
If phone not restarts byself,or after restarting software not founds phone-disconnect it from cable,put off-put on battery and connect it again to cable-software will find it and will finish flashing.
Regards,Vygis
Old 05-31-2009, 04:38   #5 (permalink)
Member: 310155
Thanks Meter: 1,313
Regards,Vygis
Thanks sir,
Phone restart byself after writing AMMS.
but after restart, its show only 2 second this language "file system startup please wait" and dn show only yellow screen,
as this condition(yellow screen) softwere cant found the phone.
ya i did this "disconnect it from cable,put off-put on battery and connect it again to cable" but same(cant found).
Old 05-31-2009, 07:28   #6 (permalink)
Cheater -Don't Deal with him-
Member: 54228
Thanks Meter: 76
try z3x box 1 file flash yr phone 100% work 40 set tested by me
Old 05-31-2009, 07:57   #7 (permalink)
Member: 310155
Thanks Meter: 1,313
oh dear !!
here talking about VYGIS.
anyway VYGIS & FG also can flash by one file, but here is problem of cant write file system.
The Following User Says Thank You to reaz.com For This Useful Post:
Old 05-31-2009, 08:16   #8 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,949
Originally Posted by reaz.com View Post
oh dear !!
Dada, did you tried to put v11 ?
Old 05-31-2009, 13:37   #9 (permalink)
Member: 310155
Thanks Meter: 1,313
Dada ki khobor ?? valo ???
ya i tryed with v11 by another tools, but same.
anyway v11 not available in VYGIS support.
Old 05-31-2009, 15:02   #10 (permalink)
Member: 310155
Thanks Meter: 1,313
same mean !!!, "cant flash by v11 or perfect file not avilable"
i thing its v10 phone.
Old 05-31-2009, 15:25   #11 (permalink)
Member: 310155
Thanks Meter: 1,313
some one give me a file, which was v11.
i thing this file is renamed(edit) file, bcoz v11 is not available.
i tried this v11 file, but same problem.
Old 05-31-2009, 16:12   #12 (permalink)
Member: 761864
Thanks Meter: 63
dont use temp.unlock files bro... use first the original one... ane post result... tested many times..
Old 05-31-2009, 17:34   #13 (permalink)
Member: 310155
Thanks Meter: 1,313
I tried this file also, but same problem "U890_V10e-H3G-AU[ORIGINAL]-EN_IT_GER_FR_SW_DA.crc"
Old 05-31-2009, 23:51   #14 (permalink)
Member: 4458
Guys-from screenshot I see ,that AMSS already is flashed,so all discussions about V11 doesn't have any sense.Problems here I see only,that software can't find phone after restarting.Possible reasons for this can be few-one is bad drivers installed,other-used USB hub,not native PC USB port.So for beginning try to reinstall drivers-take them from "/ LG / LG software / Software / Software for SmartCard dongle / LGQ-AMOI-ZTE drivers "
Also other - U890 was flashed I think by XXX users without problems,and if phone was not found by software after restarting-trick with phone disconnecting and connecting was helping always,so try it again-maybe you doing something wrong here.One more thing-try to change port number from "Device manager".
Regards,Vygis
Old 06-19-2009, 00:16   #15 (permalink)
Member: 7700
Thanks Meter: 28
sir i have u890c with show logo only, in support i can't get u890c
where i can get u890c firmware sir?
how to repair ku990i yellow screen (refreshing) 4given4gotten FuriousGold 1 03-29-2010 17:43
how to repair C3010s just show samsung screen a while then it off mantok Z3X-Team Products 0 01-04-2010 19:14
my lg ku990 shows yellow screen ufo_all LG 9 08-05-2009 21:05
C100 Only Show White Screen amol_sm VLSI, Conexant, Skyworks and Old Models 1 06-13-2007 07:29
02X1. only shows white screen and off GOODNESS Various 2 06-30-2006 11:47
Page generated in 0.24655 seconds with 10 queries
