Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 06-10-2008, 01:02   #1 (permalink)
Member: 285074
Thanks Meter: 20
CU 720 DEAD AFTER FLASH..cause. i cant unlock it with direct unlock
Cu 720 died after flash it
i try in emergency way 2+5 power...and The phone does not answer
i flash with
CU720_V10g-ATT-US[ORIGINAL]-EN_FR_ES.crc
the only flash for this model ......in the support!!!!
what can i do...please is a new phone!!!!!!!!!!!!1
Old 06-10-2008, 01:13   #2 (permalink)
Member: 4458
Thanks Meter: 25,853
At first check what voltage is on baterry? Also what version was before in phone?
Regards,Vygis
Old 06-10-2008, 15:32   #3 (permalink)
Member: 285074
Thanks Meter: 20
THE version is the same ....couse is the original flash. anda my bat. is full.....full. full....
Old 06-10-2008, 20:46   #4 (permalink)
Member: 4458
Full what means? Also other-flashing process was finished completelly? After AMMS writing phone was restarted,you seen blue screen with "Re-flashing" on LCD,when Media and Module files were written?
Regards,Vygis
P.S.I just now for one more testing flashed this 10g fw to my own CU720 and phone works OK,I even tested and uploaded to supports newer - 10l version,with it phone also not had any problems.
Old 06-10-2008, 20:57   #5 (permalink)
Member: 285074
Thanks Meter: 20
Ok full means that mybatery is completely charged
I flashe my telephone. Ultimately he said to me that if the telephone not tur it on that should press 2+5+power and that should repeat the process
Exactly I did it. For that my phone not turn it on ..and I did not see red screen either
Extract the battery and press 2+5+power exactly like the text of the window but not turn it on....
Old 06-10-2008, 21:32   #6 (permalink)
Member: 4458
One more time describe how you flashed it.Flashing process stoped somwhere? Or was completed?
Regards,Vygis
Old 06-10-2008, 21:53   #7 (permalink)
Member: 285074
Thanks Meter: 20
flashing porcess was completed..
Ok ...
I connect the telephone
Assign the flash and press write
the phone start to work......at last
show a window with the following text
If the telephone does not answer after flashar. disconnect it extract the battery press 2+5+power and start again..since the phone es DEAD
Old 06-10-2008, 22:10   #8 (permalink)
Member: 4458
Hard is with you Full charged what voltage on baterry means? Can you measure it with multimeter? Also when you was flashing phone-you not seen blue LCD with "Re-flashing" on it? Also other-when flashing is completed-software restarting phone-phone started then or not?
Regards,Vygis
Old 06-10-2008, 22:31   #9 (permalink)
Member: 285074
Thanks Meter: 20
Do not be angry
These batteries are of 3.6 with th voltimetro when are loaded they give 3.9 it means it loaded well .. (full)
When the telephone I come to 100 % of the process of flasheo
I do not restart. .. neither open any screen simply open the window that mentions you with the text that describi arrives
Old 08-26-2009, 15:39   #10 (permalink)
Member: 311174
Thanks Meter: 5
Also having some trouble.
I am also having this problem, and I originally bought my box for this phone. Is there some other way to flash a CU720, or a way to get it out of Re-Flashing mode? I have tried to use the Emergency Download, but it did not work. Please send information as soon as you know...
Thanks,
techsign.
Old 10-03-2009, 22:52   #11 (permalink)
Member: 219211
i have the same problem, the batery is full charge.... i tried emergency download procedure, but not luck.... the phone still saying Re.flashing...please any solution?
Old 10-04-2009, 03:38   #12 (permalink)
Member: 4458
What flash you tried exactly?
Regards,Vygis
Can't Unlock 8180 With Direct Unlock ? tcom25100 VygisToolbox 3 08-01-2006 07:35
E-720 Dead After Flashing ziober Trident/AGERE Platform 6 08-15-2005 17:56
after flaSHING T68M FOR NO ACCESS IT WENT DEAD gbada Sony Ericsson 1 10-21-2004 11:32
T-720i DEAD AFTER FLASH T-720 WITH PST KINK Motorola P2k 15 07-21-2003 10:12
T191 dead after flashing. how to repair it? phonesoft Motorola ODM 2 01-29-2003 17:04
Page generated in 0.33888 seconds with 8 queries
