04-11-2009, 11:56 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: punjab india
Member: 421487 Status: Offline Thanks Meter: 58 | cu500 dead during flashing[ unlocking ] |
04-11-2009, 13:13 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | None box will alive it,because you don't read "Unlocker help.txt" file and also don't read what software writes.Let begin again : Software near phone model writes : "USB cable" - if you would read "Unlocker help.txt" file,you would see : UNLOCKER HELP ================================================== ============================== For starting to work with software,you need to have LG USB cable-mostly is included to phone's package and drivers-"LGUSBModemDrivers" installed. For LG KS20 - "LGCoronaUSBDrivers" must be installed. 1.Connecting phone : - power ON phone and connect it to USB cable - start software - select baudrate 115200,check "Enumerate PORTS" and "Auto find PORT" - select phone model - press "CONNECT PORT" - if software writes "Can't find needed COMPORT"-check cable and drivers instalation - after port connecting,press "CONNECT PHONE" - wait until software will read phone's info - if selected phone model differs from phone type,readed from phone, software can ask you what phone type you want to set Some new models like CU915,CU920 and TU920 must be connected in next way : - power OFF phone and connect it to USB cable. - Wait until phone will power ON and will show on LCD "Battery charging", - press "CONNECT PORT",press "CONNECT PHONE" and make your needed operations. WARNING! Use only native PC USB port,not use any external USB hubs About what cable is written in help-if not read it before-now you can see- it writes about USB cable. Now your actions-you use RJ45 cable,because seems not had USB cable. So you starting to flash phone and ofcourse will have not finished AMSS file writing,here is what you wrote in one of previous posts,here copy paste of your post: dear team every time same error when i write patch unlock file pl tel me where is i am wrong i use infinty rj45 [7050 cabel, vigis rj 45 7050 cabel and] but no result Connecting ... OK Connected in EMERGENCY MODE ---------------------------------------------------------- Writing flash from file : CU500_CU500V_V10a-CINGULAR[UNLOCKED]-EN_FR_ES.crc Checking flash files ... OK ---------------------------------------------------------- Writing PARTITION TABLE ... OK ---------------------------------------------------------- Writing PBL ... OK ---------------------------------------------------------- Writing QCSBL ... OK ---------------------------------------------------------- Writing OEMSBL ... Operation failed ---------------------------------------------------------- Writing flash from file : CU500_CU500V_V10a-CINGULAR[UNLOCKED]-EN_FR_ES.crc Checking flash files ... OK ---------------------------------------------------------- Writing PARTITION TABLE ... OK ---------------------------------------------------------- Writing PBL ... OK ---------------------------------------------------------- Writing QCSBL ... OK ---------------------------------------------------------- Writing OEMSBL ... Operation failed ---------------------------------------------------------- Writing flash from file : CU500_CU500V_V10a-CINGULAR[UNLOCKED]-EN_FR_ES.crc Checking flash files ... OK ---------------------------------------------------------- Writing PARTITION TABLE ... OK ---------------------------------------------------------- Writing PBL ... OK ---------------------------------------------------------- Writing QCSBL ... OK ---------------------------------------------------------- Writing OEMSBL ... Operation failed ---------------------------------------------------------- Writing flash from file : CU500_CU500V_V10a-CINGULAR[UNLOCKED]-EN_FR_ES.crc Checking flash files ... OK ---------------------------------------------------------- Writing PARTITION TABLE ... OK ---------------------------------------------------------- Writing PBL ... OK ---------------------------------------------------------- Writing QCSBL ... OK ---------------------------------------------------------- Writing OEMSBL ... OK ---------------------------------------------------------- Writing AMSS ... Operation failed As I see RJ45 cable here was used,and this is bad-because CU500 needs all AMSS would be written,as boot sectors are splited to 2 parts-one at beginning of AMSS-other at the end.So if AMSS was not flashed total-boot is damaged and no way to alive phone. So for this reason actually we landed with lost phone. Regards,Vygis |
11-21-2009, 14:51 | #3 (permalink) |
Member: 421487 Status: Offline Thanks Meter: 58 | dear sir now a days have you asolution of this dead cu500 dead during unlocking if [ it cannot be enter in emergency mode] yes pl ans or whitch other box can live this phone pl reply me |
CU500 Dead after flash | Fabiano | VygisToolbox | 9 | 09-15-2008 23:42 |
Panasonic GD87 dead during flashing????? | .::Zafar Communication::. | Panasonic | 9 | 06-18-2005 00:13 |
Panasonic X70 Dead During Flashing | axilleask | Panasonic | 18 | 10-22-2004 19:30 |
A300 dead - during flashing suddenly stoped | gladeo | VLSI, Conexant, Skyworks and Old Models | 1 | 04-04-2003 00:34 |
Help!!! Mars is dead during flashing... | Roman | Mitsubishi | 1 | 11-27-2001 20:20 |
