09-15-2014, 19:34 | #1 (permalink) |
Insane Poster Join Date: Oct 2004 Location: Brazil
Member: 85464 Status: Offline Sonork: 100.1620941 Thanks Meter: 5 | E450F flash error I can't write the support flash file (using p999 cable or usb) log Connecting phone - connect USB cable to phone, phone must be OFF - if you can't connect using micro USB cable - use P999 cable (with 910k resistor) ... Opening USB Port (COM95) ... OK ---------------------------------------------------------- Loading primary loader ... OK Executing loader ... OK Reading flash info ... OK ---------------------------------------------------------- Reading phone info,please wait ... OK ---------------------------------------------------------- Writing flash from file : LG-E450F_LGE450fAT-00-V10a-724-XXX-MAR-28-2013_GER_EN_ES_FR_IT_NL_PL_PT_SW_KOR.crc Extracting flash files, please wait ... OK ---------------------------------------------------------- Getting flash file params ... OK Formating ANDROID ... OK Formating CACHE ... OK Formating USRDATA ... OK Getting bootloader params ... OK Setting bootloader params ... OK Writing BL 0 ... OK Writing BL 1 ... OK Writing BL 2 ... OK Writing MBR ... No ACK after write block command Operation failed |
09-15-2014, 21:43 | #2 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Charge fully battery and use computer with windows 7 32bit in win xp some problem egsist with flashing new lg phones. |
The Following User Says Thank You to wgmmmx1 For This Useful Post: |
09-17-2014, 17:04 | #4 (permalink) |
Member: 85464 Status: Offline Sonork: 100.1620941 Thanks Meter: 5 | full batery windows 7 and the same error... Getting flash file params ... OK Formating ANDROID ... OK Formating CACHE ... OK Formating USRDATA ... OK Getting bootloader params ... OK Setting bootloader params ... OK Writing BL 0 ... OK Writing BL 1 ... OK Writing BL 2 ... OK Writing MBR ... No ACK after write block command Operation failed Vygis i need your help! thanks |
