11-17-2014, 05:50 | #1 (permalink) |
Junior Member Join Date: Jan 2012 Location: CUCUTA-COLOMBIA Age: 31
Member: 1715183 Status: Offline Sonork: 100.1626322 Thanks Meter: 3 | e450g error flash Connecting phone - connect USB cable to phone, phone must be OFF - if you can't connect using micro USB cable - use P999 cable (with 910k resistor) ... Opening USB Port (COM30) ... OK ---------------------------------------------------------- Loading primary loader ... OK Executing loader ... OK Reading flash info ... OK ---------------------------------------------------------- Reading phone info,please wait ... OK ---------------------------------------------------------- Writing flash from file : LG-E450G_LGE450gAT-00-V10b-AMX-XXX-APR-23-2013_GER_EN_ES_FR_IT_NL_PL_PT_SW_KOR.crc Extracting flash files, please wait ... OK ---------------------------------------------------------- Getting flash file params ... OK Formating ANDROID ... OK Formating CACHE ... OK Formating USRDATA ... OK Getting bootloader params ... OK Setting bootloader params ... OK Writing BL 0 ... OK Writing BL 1 ... OK Writing BL 2 ... OK Writing MBR ... No ACK after write block command Operation failed |
05-02-2015, 20:36 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: salina cruz, oaxaca, mèxico Age: 59
Member: 296918 Status: Offline Thanks Meter: 122 | E450g flash error Same error (using usb and 910k resistorr cables): Connecting phone - connect USB cable to phone, phone must be OFF - if you can't connect using micro USB cable - use P999 cable (with 910k resistor) ... Opening USB Port (COM12) ... OK ---------------------------------------------------------- Loading primary loader ... OK Executing loader ... OK Reading flash info ... OK ---------------------------------------------------------- Reading phone info,please wait ... OK ---------------------------------------------------------- Writing flash from file : E450g telefonica.crc Extracting flash files, please wait ... OK ---------------------------------------------------------- Getting flash file params ... OK Formating ANDROID ... OK Formating CACHE ... OK Formating USRDATA ... OK Getting bootloader params ... OK Setting bootloader params ... OK Writing BL 0 ... OK Writing BL 1 ... OK Writing BL 2 ... OK Writing MBR ... No ACK after write block command Operation failed |
