06-17-2005, 22:20 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | FULL FLASH File for U8180 dead phones repairing / unlocking in 22 min here It can be used of course also for unlocking. NOTICE: Can be flashed at 921kb/s (~22 min) DO NOT FORGET TO PRESS ALSO RELOCK then UNLOCK AFTER FLASHING (read better the instructions) http://www.vygistoolbox.com/download...3&id_brand=334 [/glow] thx to SER and DANGSM regards, Gobi Last edited by Gobi; 06-19-2005 at 08:12. |
06-18-2005, 16:57 | #3 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: YODAFON
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | Quote:
br | |
06-18-2005, 21:19 | #4 (permalink) |
Freak Poster Join Date: Aug 2002 Location: iasi, Romania Age: 49
Member: 14258 Status: Offline Thanks Meter: 3 | After flash unlock the phone and just go in the hide menu and reset the phone and is unlocked......without enter the codes. Last edited by mariangsm; 06-18-2005 at 21:43. |
06-18-2005, 21:37 | #5 (permalink) |
Member: 14258 Status: Offline Thanks Meter: 3 | and......if the time is the problem,if you have many phones for unlock......simple solution:you can use on the seem time for flashing 2 phones(in one pc),1pcs on usb,1pcs on serial(com 1,but slow speed).Another solution is to use many pc,use the dongle(usb) start the sw for flashing,remove the dongle,(sw is still running), put in the another pc and repeat the operation......... |
06-19-2005, 00:38 | #6 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Sousse - Tunisia
Member: 71620 Status: Offline Thanks Meter: 8 | This can Speep Up ur COM1 port u can flash on 460000 and 912000 depending on ur MotherBoard CHIP => on my comp i flash on 460000 TESTed and Approved http://www.rippstein.net HiSerial.sys Driver V1.5 The driver is designed for Windows XP and Windows 2000. Maximum COM port speed is 921600 Baud depending on the computers chipset. Not supported chipsets work with 115200 Baud. Downloads with up to 15,6 kB/sec are possible. With activated modem compression even higher values are possible because the COM port no longer is the bottleneck. Currently the following chipsets are supported: ALi M1543 @ max. 460800 baud ALi M1543C @ max. 460800 baud ALi M5133 @ max. 460800 baud ALi M1535 @ max. 460800 baud ALi M1535D @ max. 460800 baud ITE IT8761F @ max. 460800 baud ITE IT8661F @ max. 115200 baud ITE IT8673F @ max. 115200 baud ITE IT8700F @ max. 115200 baud ITE IT8702F @ max. 115200 baud ITE IT8705F @ max. 115200 baud ITE IT8710F @ max. 115200 baud ITE IT8711F @ max. 115200 baud ITE IT8712F @ max. 115200 baud SMSC FDC37B72x @ max. 460800 baud SMSC FDC37B77x @ max. 460800 baud SMSC FDC37M77x @ max. 460800 baud SMSC FDC37B78x @ max. 460800 baud SMSC FDC37B80x @ max. 460800 baud SMSC FDC37M70x @ max. 460800 baud SMSC FDC37C67x @ max. 460800 baud SMSC FDC37C68x @ max. 460800 baud SMSC FDC37C93x @ max. 460800 baud SMSC FDC37C93xAPM @ max. 460800 baud SMSC FDC37C93xFR @ max. 460800 baud SMSC FDC37M60x @ max. 460800 baud SMSC FDC37M61x @ max. 460800 baud SMSC FDC37M81x @ max. 460800 baud SMSC FDC37N958FR @ max. 460800 baud SMSC FDC37N971 @ max. 460800 baud SMSC FDC37N972 @ max. 460800 baud SMSC FDC37C957FR @ max. 460800 baud SMSC LPC47B27x @ max. 460800 baud SMSC LPC47B37x @ max. 460800 baud SMSC LPC47M10x @ max. 460800 baud SMSC LPC47M14x @ max. 460800 baud SMSC LPC47M120 @ max. 460800 baud SMSC LPC47M15x @ max. 460800 baud SMSC LPC47M192 @ max. 460800 baud SMSC LPC47N252 @ max. 460800 baud SMSC LPC47S42x @ max. 460800 baud SMSC LPC47S45x @ max. 460800 baud SMSC LPC47U33x @ max. 460800 baud SMSC LPC47U32x @ max. 460800 baud SMSC FDC37C665IR @ max. 460800 baud SMSC FDC37C666IR @ max. 460800 baud SMSC FDC37C669 @ max. 460800 baud SMSC FDC37C669FR @ max. 460800 baud SMSC FDC37N769 @ max. 460800 baud SMSC FDC37N869 @ max. 460800 baud SMSC FDC37N3869 @ max. 460800 baud SMSC LPC47N227 @ max. 460800 baud SMSC LPC47N267 @ max. 460800 baud SMSC FDC37C665GT @ max. 115200 baud SMSC FDC37C666GT @ max. 115200 baud National Semiconductor PC87108 @ max. 115200 baud (No detection) National Semiconductor PC87109 @ max. 115200 baud (No detection) National Semiconductor PC87303 @ max. 115200 baud National Semiconductor PC87306 @ max. 115200 baud National Semiconductor PC87310 @ max. 115200 baud (No detection) National Semiconductor PC87311A/312 @ max. 115200 baud (No detection) National Semiconductor PC87332VLJ/VLJ-5 @ max. 115200 baud National Semiconductor PC87317 @ max. 921600 baud National Semiconductor PC87334VLJ/VJG @ max. 115200 baud National Semiconductor PC87336 @ max. 115200 baud National Semiconductor PC97317 @ max. 921600 baud VIA VT82C686A/B @ max. 460800 baud Winbond W83627GF-AW @ max. 921600 baud Winbond W83627SF @ max. 921600 baud Winbond W83627F @ max. 921600 baud Winbond W83627HF @ max. 921600 baud Winbond W83697HF @ max. 921600 baud Winbond W83697SF @ max. 921600 baud Winbond W83877ATF @ max. 921600 baud Winbond W83877F @ max. 115200 baud Winbond W83877TF @ max. 921600 baud Winbond W83977AF @ max. 921600 baud Winbond W83977ATF @ max. 921600 baud Winbond W83977CTF @ max. 921600 baud Winbond W83977EF @ max. 921600 baud Winbond W83977TF @ max. 921600 baud Winbond W83L517D @ max. 921600 baud Download HiSerial.sys Driver Setup (301 kB) Your chipset is not yet supported? Please contact me with technical details. You are looking for a solution for Windows 95/98/2000? Try SHSMOD. |
06-20-2005, 07:38 | #8 (permalink) |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | hi Gobi.....can we use this flash files for unlocking without testpoint or with testpoint.. should we use testpoint during flashing these files or not? |
06-20-2005, 08:51 | #9 (permalink) | |
Registered User Join Date: Aug 2003 Age: 41
Member: 36653 Status: Offline Thanks Meter: 336 | use it in booting the phone Quote:
FULL FLASH File for U8330 dead phones repairing / unlocking in 22 min here | Gobi | VygisToolbox | 43 | 12-09-2009 18:03 |
We are looking for Full Flash Files read from Chinese Phones with Infineon CPU | nonu_don | ET-BoX | 8 | 10-16-2008 12:09 |
lg 8130r full flash needed to revive dead phone | jesto80 | Sonics Box | 9 | 08-11-2005 01:30 |
lg 8130r full flash needed to revive dead phone | jesto80 | Blazer | 0 | 08-07-2005 01:12 |
V2288 full flash file for repair bad flash phone: | M|ster|oS | Motorola Old Legacy (EMMI) | 4 | 03-24-2004 10:54 |
