GD330 no display after flash. hii flash a gd330 from telcell after flash no display phone works ok before flash, but nowcan make calls and everything but no display. i have flashed avery single firmware in support but allways the same. any help would be appreciated. |
It is very hard to say where is problem-anyway I uploading now to supports GD33AT_V10m-EUR-XX flash-it is latest available GD330 flash-please try it Regards, Vygis |
im downloading it now by the way do u have any firmware from telcel mexico cos that was the original. |
i have flash the phone with this D33AT_V10m-EUR-XX but same thing. any other suggestion?. |
any solution?........ |
I've the same problem with lg gd330!! hi, I've the same problem, I tried to put flash (firmware & eeprom) with vygis and furious and I obtained the same result, I need your help!! the phone is from telcel méxico, the problem was that the phone freezed on the log lg thanks br |
I will try to upload to supports original Telcel flash tonight Regards, Vygis |
good support by vygis :) |
That is correct, this is the solution for our problem, only flash the phone with firmware "GD330HL-01-V10a-334-20-MAY-27-2009+3". download this file from vygis support. It's from telcel méxico. it works perfectly, tested, works 100% thanks vygisim br |
