Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 02-17-2010, 16:22   #1 (permalink)
Member: 69382
GD510 Imei Fix [SOLVED]
What is the procedure to fix imei on gd510? I have connected phone by tp on PCB and pushed enable write IMEI. what do i need to do after ? when i connect turned on phone by TP on PCB and push read imei software writing that failed imei reading...
Old 02-18-2010, 11:41   #2 (permalink)
Member: 69382
Please vygis help me....
Old 02-25-2010, 17:18   #3 (permalink)
Member: 132496
Any news about this??
Old 04-09-2010, 13:19   #4 (permalink)
Member: 69382
Originally Posted by tatek View Post
any news about this??
nothing!!!.........
Old 04-10-2010, 23:05   #5 (permalink)
Member: 4458
If you can't read-write IMEI with TP on PCB- then use GW300 cable,phone must be powered on and without SIM
Regards, Vygis
Old 04-10-2010, 23:12   #6 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
Regards, Vygis
Tried both methods, but still doesn't work?
WBR
Old 04-10-2010, 23:30   #7 (permalink)
Member: 4458
You mean tried with GW300 RJ45 cable also? You can read IMEI?
Regards, Vygis
Old 04-12-2010, 11:04   #8 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
Regards, Vygis
Yes, tried with GW300 & GD510 TP. Both ways i can unlock with but can't even read the imei of it?
WBR
Old 04-14-2010, 22:47   #9 (permalink)
Member: 4458
This is impossible-anyway try next-1809#*510# to enter test menu-later "Factory reset" and later try read IMEI again.
Regards, Vygis
Old 05-04-2010, 19:47   #10 (permalink)
Member: 333519
Sonork: 100.1620327
same problem here, when i press read imei i get operation failed, please help
Old 05-05-2010, 00:54   #11 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
Same for me?
WBR
Old 05-27-2010, 08:33   #12 (permalink)
clone's Avatar
Member: 19327
For me the read imei works fine,but the write : operation failed . Try with gd510 tp and gw300 cable, with same result .
Old 05-27-2010, 08:37   #13 (permalink)
Member: 4458
You need to make "Enable Write IMEI" before.Also please use latest LGI version.
Regards, Vygis
Old 05-27-2010, 08:48   #14 (permalink)
clone's Avatar
Member: 19327
Regards, Vygis
Old 05-27-2010, 09:31   #15 (permalink)
Member: 4458
You pressed before "Enable Write IMEI" when phone is booted?
Regards, Vygis
P.S.If yes-please upload here eeprom from phone
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 11-21-2011 00:44
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-08-1999 14:22
Imei Arnis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-15-1999 02:38
Page generated in 0.35391 seconds with 12 queries
