GD510 security code -- how to reset [ ANSWERED ] How to reset GD510 security code pls? i've got only usb cable. i came to know from the forum that if the phone has got security code enabled only flashing is possible thru usb cable. Has anyone removed sec code thru flashing? Or is there any new quick solution for this? pls advice. |
If phone no full locked try 1809#*510# |
I have one a GD510 that I need to remove security code. I only have a Nokia USB data cable. Is it possible to remove it with it? Thanks |
have your tried with (rj45) gw300 cable? and factory reset? |
Can I use the USB cable? |
YES..use the USB cable |
How do I change to USB ? Thanks |
If phone is locked with USB cable you can only to flash phone-for unlocking will be needed GW300 cable. Regards, Vygis |
Please guide me Thanks |
At first - have you tried 1809#*510# and later "Factory reset"? How to flash phone via USB is described in "Help_EN.doc" file-it goes together with software. Regards, Vygis |
Connecting phone - connect USB cable to phone, phone must be OFF and without battery ... Driver connected, connecting phone ... OK ---------------------------------------------------------- Changing baudrate ... OK Setting bus ... OK Loading certificate ... OK ---------------------------------------------------------- Reading phone info ... OK ---------------------------------------------------------- Writing flash from file : GD510AT-00-V10b-EUR-XX-SEP-22-2009_EN_BUL_CRO_CZ_DA_NL_FIN_FR_GER_GR_HU_IT_FYROM _NO_PL_PT_RO_SERB_SLO_SK_ES_SW_TR_RR_KZ_LV_LT_RU_U KR_CN_INDON_MALAY_THAI_VIET_KOR.bin ---------------------------------------------------------- Checking flash file ... OK Extracting flash files ... OK Writing flash ... OK ======== Process completed ======== Operation time - 0:05:28 Only problem now is the screen calibration not working. Phone makes and receive calls ok. |
Have you read this : At first - have you tried 1809#*510# and later "Factory reset"? If not-try now Regards, Vygis |
Hey thnx this code really works if the phone is not locked fully just dial it from your dialler 1809#*510# |
