Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 03-31-2010, 22:29   #1 (permalink)
kushstha's Avatar
Member: 473763
Thanks Meter: 56
GD510 security code -- how to reset [ ANSWERED ]
How to reset GD510 security code pls?
i've got only usb cable.
i came to know from the forum that if the phone has got security code enabled only flashing is possible thru usb cable.
Has anyone removed sec code thru flashing?
Or is there any new quick solution for this?
pls advice.
Old 04-01-2010, 08:51   #2 (permalink)
Member: 245363
Thanks Meter: 5
If phone no full locked try 1809#*510#
The Following 4 Users Say Thank You to fitserwis For This Useful Post:
Old 05-22-2010, 20:23   #3 (permalink)
Member: 220143
Thanks Meter: 95
I have one a GD510 that I need to remove security code. I only have a Nokia USB data cable. Is it possible to remove it with it?
Thanks
Old 05-23-2010, 12:59   #4 (permalink)
pyjaman's Avatar
Member: 232856
Thanks Meter: 69
have your tried with (rj45) gw300 cable? and factory reset?
Old 05-25-2010, 18:00   #5 (permalink)
Member: 220143
Thanks Meter: 95
Thanks but I nly have USB cable.
Can I use the USB cable?
Old 05-25-2010, 18:21   #6 (permalink)
Member: 857869
Thanks Meter: 3
YES..use the USB cable
Old 05-25-2010, 19:05   #7 (permalink)
Member: 220143
Thanks Meter: 95
Do I have to place the phone in test mode or something. Plus VYGIS only one cable option, RJ45 ?
How do I change to USB ?
Thanks
Old 05-25-2010, 20:15   #8 (permalink)
Member: 4458
Thanks Meter: 25,853
If phone is locked with USB cable you can only to flash phone-for unlocking will be needed GW300 cable.
Regards, Vygis
Old 05-28-2010, 15:43   #9 (permalink)
Member: 220143
Thanks Meter: 95
Regards, Vygis
Thanks. But can flashing remove he user lock code? I only have nokia USB cable can this be used? And how do I proceed doing with flashing , do I put the phone in som kinda flash mode?
Please guide me
Thanks
Old 05-28-2010, 19:26   #10 (permalink)
Member: 4458
At first - have you tried 1809#*510# and later "Factory reset"? How to flash phone via USB is described in "Help_EN.doc" file-it goes together with software.
Regards, Vygis
The Following User Says Thank You to vygism For This Useful Post:
Old 05-29-2010, 00:40   #11 (permalink)
Member: 220143
Thanks Meter: 95
Regards, Vygis
Yes flashed successfully. See logs:-
Connecting phone - connect USB cable to phone, phone must be OFF and without battery ...
Driver connected, connecting phone ... OK
Changing baudrate ... OK
Setting bus ... OK
Loading certificate ... OK
Reading phone info ... OK
Writing flash from file : GD510AT-00-V10b-EUR-XX-SEP-22-2009_EN_BUL_CRO_CZ_DA_NL_FIN_FR_GER_GR_HU_IT_FYROM _NO_PL_PT_RO_SERB_SLO_SK_ES_SW_TR_RR_KZ_LV_LT_RU_U KR_CN_INDON_MALAY_THAI_VIET_KOR.bin
Checking flash file ... OK
Extracting flash files ... OK
Writing flash ... OK
======== Process completed ========
Operation time - 0:05:28
Only problem now is the screen calibration not working. Phone makes and receive calls ok.
Old 05-29-2010, 01:11   #12 (permalink)
Member: 4458
Have you read this :
At first - have you tried 1809#*510# and later "Factory reset"? If not-try now
Regards, Vygis
Old 10-14-2010, 14:34   #13 (permalink)
Member: 1417085
Hey thnx
this code really works if the phone is not locked fully
just dial it from your dialler
1809#*510#
The Following User Says Thank You to husain4u For This Useful Post:
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.36874 seconds with 8 queries
