Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 06-22-2006, 04:03   #1 (permalink)
Member: 266574
@Gobi, how to use vygis toolbox????
hi gobi,
I'm a newbe, I've just buy a vygis toolbox from my friend in few weeks ago,
at the first time I tried to flash motoacer (I already buy the reg files from Simsim yesterday)I've download the software and already to use. but I don,t know how to flash it.
guys, give me some info to
how to flash with vygis toolbox
what cable that I have to use for flash Motoacer, lg, sharp....
Old 06-22-2006, 07:29   #2 (permalink)
kasner's Avatar
Member: 56469
So visit support area, download manual and read it.
BR Kasner
Old 06-27-2006, 03:52   #3 (permalink)
Member: 266574
thx @kasner
thx, I didnt find any manual in support site, maybe I went to wrong address.
I only download the USB PROGAMER manual.
could you tell me the right address pls??
what is usb programer,when do I use it?
thx
Vanbasten
Old 06-27-2006, 07:47   #4 (permalink)
benguetcowboy1's Avatar
Member: 51716
Sonork: 100.1594676
ngeekkkk
thx
Vanbasten
obviously your fishing in the dessert .... find where the sea is and you will find something there bossssssssss
Old 06-27-2006, 18:53   #5 (permalink)
Member: 266574
@benguetcowboy1
hahah....
could you tell me where to find the address to download vygis user manual?
THX
Vanbasten
Old 06-27-2006, 22:47   #6 (permalink)
Member: 4458
If to say true-manual for Motorola Acer software not exist,as I think,that all user interface is simple enough- to be lost in few buttons it is enough hard
Also from practice-user manuals or even short instructions read 1 man from 100,so to lose week or few weeks for normal instruction making not have sense.If you are still lost with software,please discribe your problem more exactly.
Regards,Vygis
Old 06-28-2006, 01:24   #7 (permalink)
Member: 51716
Sonork: 100.1594676
ay apo
hahah....
THX
Vanbasten
you can have direct support access from your software SADOT/TAMAD!!!!
Old 06-28-2006, 02:42   #8 (permalink)
Member: 266574
@vygism
my problem are
1.how to conect my motorola
2.how to use com in vygisbox software, because I always see choice to use com1/2/3?
3.can I use rj45 cable if I choose com1 in the software?
thx
br
Vanbasten
Old 06-28-2006, 08:58   #9 (permalink)
Gobi's Avatar
Member: 6328
auuuaauauuaauuaauuuuuuuuuuuuuuuuuuuuuuuuuuu
Old 06-28-2006, 11:01   #10 (permalink)
Member: 4458
OK,let begin from beginning I think,that you have Vygistoolbox,so left RJ45 on box is "USB to RS232 by Vygisoft" and right RJ45 is COM.Which COM depends to what Comport on PC box is connected with COM cable.
You can choose here what port you want use,I mean you can connect to left or right RJ45.Let imagine,that you connect to left RJ45.In software ,
under "Port & Settings" select "USB to RS232 by Vygisoft" and 812500 baudrate,select phone model under "Phone type".Check that switch on box is set to "F-BUS".Now again look to software,you see,that almost all buttons are inactive,except "Connect" and software writes "Waiting for action".If to think logicaly-you need to press "Connect" as only this button is active
So press "Connect"-software write "Please power ON phone"-now press power ON on phone(phone must be connected with cable to left RJ45).Wait until bootloader will be loaded to phone,after this software reads info from phone and all buttons become active.After this choose your action again.If you need to make unlock -choose "Fast unlock" or "Read unlock code",if you want to flash phone-select by checking flashing options checkbox,what you want to flash-firmware,eeprom and full,later select flash file and press "Write flash" and etc.
If you selected before not left,but right RJ45,under "Port & Settings" select ComPort,to which box is connected and set 115200 baudrate(Windows not allows higher baudrates than 115200 without special drivers).After this do everything same like is described before.
Regards,Vygis
Old 06-29-2006, 10:00   #11 (permalink)
Member: 266574
@vygism
thx for the info......
Vanbasten
Old 10-22-2007, 16:06   #12 (permalink)
Member: 447709
Hello, when use "M-BUS" ??
Old 10-22-2007, 19:17   #13 (permalink)
Member: 4458
Never
Regards,Vygis
Old 10-23-2007, 10:52   #14 (permalink)
Member: 447709
Why is it implemented?
Old 11-03-2009, 13:46   #15 (permalink)
Swazi_Gsm's Avatar
Member: 317494
Sonork: 1000.1984
how to use usb can u explain me in lg ? can i unlok ks360 via usb
i need user manuale for vygis if u can
Page generated in 0.73603 seconds with 10 queries
