05-13-2006, 09:35 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | For Gobi and Vygis---Some questions! Ok, i have your tool now, and wanted to use the Sharp part to unlock and repair imei's on some gx15/25's that i have comnig, but it doesnt appear to support them, is there a particular model i need to select or..... Also when i try to open 02X1_1_2sc it just sats 'Protection Card not found!' and doesnt open the program! It also does this on MicroSnapper tool as well, and yet all the others work fine! What do i need to do to fix this? I currently at the same time on my pc: Usb Smart/Infinity/UST ProII/Vygis if that helps in anyway! |
05-13-2006, 14:46 | #2 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | - gx15 and gx25 are unfortunately not supported. - 02X1 and Microsnapper work with the LG reg file. Please check to have only this reg file in the directory, and disconnect any other dongle from the pc when launching the softwares (one software at one time) Then it must work. regards, Gobi |
05-13-2006, 18:16 | #3 (permalink) | |
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Quote:
have tried your suggestions, but still says 'Card Protection not Found' Any other ideas? | |
05-13-2006, 19:59 | #4 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | If you have no other smartcard dongle connected to the pc, only the right red file in the directory, and no other software open --> then i really cannot imagine what is wring there ... regards, Gobi |
05-13-2006, 21:47 | #5 (permalink) | |
i will try it on my laptop and let you know the outcome, there is nothnig on my laptop at all, so if same problem occurs then.... | |
05-14-2006, 11:52 | #6 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Bangladesh
Member: 37349 Status: Offline Sonork: 100.1613413 Thanks Meter: 362 | Hi M8, it can be virus pb of pc.before a few days ago i also fallen such as pb & then clean pc with antivirus & now everything is ok & i have seen that such as virus only infected the drive's system volume folder which is contains into every hdd drive as hidden.so,lets chk about virus & i hope if ur other everything is ok then it should be workful. proxy_gsm |
@Gobi and @ Vygis , LG1.70 bug report | Leshy | VygisToolbox | 2 | 02-05-2007 10:00 |
Gobi and vygis please help? | zakariababu | VygisToolbox | 2 | 12-25-2006 14:55 |
?.+GOBI and vygis...please support acer new | halongmobile | VygisToolbox | 0 | 08-02-2006 06:07 |
small small question for Gobi and the team vygis | giuseppe1374 | VygisToolbox | 1 | 06-15-2006 22:08 |
to Gobi and Vygis plizz see this from wray | the new | VygisToolbox | 2 | 08-24-2005 09:09 |
