Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 01-16-2012, 22:34   #1 (permalink)
Member: 119254
Sonork: buhu_6
gw620 after readin instruction not done
Symptoms: Phone ***** shows LG Logo and the goes to black screen with "Arm11 crashed" text
How to repair:
PROCEDURE I
-Install drivers and restart PC after installation
A.LGUnitedMobileDriver_S4981MAN35AP22_ML_WHQL_Ver_ 3.5.exe or higher version
B.LGWindowsMobile_USBDriver_WHQL_ML_Ver_1.0.exe or higher version
C.LGSmartPhone_ModemlinkDUNDrive_WHQL_ML_Ver_1.0.e xe
-Install msxml.msi, if is not installed already
-Set phone in Emergency mode. ( Power Off. Keep pressing key 1 on the keyboard and plug in the USB cable)
-Go FAST, after drivers are installed, to the device manager and disable the : LG Mobile USB Modem ( Under MODEMS)
-Open the software KDZ_FW_UPD.exe and set Type:3GQCT and PhoneMode: EMERGENCY
-Select KQZ file : V10G_00.kdz
-Finaly Press the : Launch Software update button
-Wait till software extracts file to V10G_00.cab and starts flash process
-After some minutes phone will exit emergency and starts charging. Press Power ON button shortly and let phone Boot
-After a while Software will show =FINISHED=
-Must wait some minutes till Phone exit ANDROID Logo and starts normaly.
-If stucks there, use VYGIS to Factory Reset phone.
PROCEDURE II
In case that this process does not repair phone do as follows:
-Open the software KDZ_FW_UPD.exe and set Type:3GQCT-SmartPhone(WM)
-Select KQZ file : V10E_00.kdz
-Press the : Launch Software update button and wait process to finish
-Probably you end-up with black screen with "Arm11 crashed" text, but is not a problem.
-Now just flash again as explained at Procedure I
This is how i personaly repaired one phone which was branded to Orange and killed after flashing with VYGIS
i try these procdure step by step on clean pc and after don my mobile stil arm11 crashed an other solution plz help me vygis supporter i'm indeed for you're help thanks for you and you're support
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 03-07-2000 21:24
Nokia 5110 - "SIMcard not accepted". Kond Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 03-02-2000 21:46
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 01-26-2000 13:31
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-28-1999 14:56
Page generated in 0.19793 seconds with 11 queries
