08-14-2009, 12:02 | #4 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | You not finished to flash phone- read "Unlocker help.txt" and "Flasher help.txt" files.You need to wait until software will write "Process completed" - flashing time for KU990 is about 18 minutes as i remember. Regards,Vygis |
08-31-2009, 23:39 | #9 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | normally just flash it and after unlock it, for flashing using Download mode, not power on phone, because if the phone is power on in normal mode, some time fllasing don't finish, and give you error. Best Regards, JAVA Good. |
09-01-2009, 00:12 | #11 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Cali Colombia Age: 43
Member: 181405 Status: Offline Thanks Meter: 249 | LG Qualcomm phones from H3G network has different "MEDIA" files,depending from country-region.If you will write flash with not correct region-phone will show "Unavailable MEDIA file".If flash file,which you want to write to phone has different region from you phone's country,before flash writing check "Change Region" and select needed country-region. |
HELP!!HOW to repair the ku990 "unavailable otp block" by vygis | 北京混混 | VygisToolbox | 25 | 06-24-2011 10:21 |
how to repair ku990i yellow screen (refreshing) | 4given4gotten | FuriousGold | 1 | 03-29-2010 17:43 |
Can anyone know how to repair THE LCD circuit of V3 (moto)excluding main PCB board | dread_mastah | Motorola Hardware Repair | 0 | 01-09-2010 17:42 |
Help how to disable the Pen Calibration of N95 Single sim | Dj King | Infinity-Box | 6 | 08-09-2008 22:56 |
How to repair the IMEI to ORIGINAL on KU990 & KE990 when damaged by free solutions | AlexG | LG | 14 | 05-19-2008 00:33 |
