Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 08-14-2009, 09:35   #1 (permalink)
Member: 1090111
Thanks Meter: 15
HELP!!!!How to repair the yellow screen of KU990 by VYGIS
Old 08-14-2009, 09:48   #2 (permalink)
Member: 4458
Thanks Meter: 25,853
What is written on yellow screen?
Regards,Vygis
Old 08-14-2009, 11:55   #3 (permalink)
Member: 1090111
Thanks Meter: 15
Regards,Vygis
refreshing(yellow screen)
Old 08-14-2009, 12:02   #4 (permalink)
Member: 4458
You not finished to flash phone- read "Unlocker help.txt" and "Flasher help.txt" files.You need to wait until software will write "Process completed" - flashing time for KU990 is about 18 minutes as i remember.
Regards,Vygis
Old 08-14-2009, 12:03   #5 (permalink)
Member: 1090111
Thanks Meter: 15
unavailable
otp block
Old 08-14-2009, 12:05   #6 (permalink)
Member: 4458
Make "Direct unlock" And read helps As after 10 minutes I will leave home and guess, that you still will be asking hor help
Regards,Vygis
Old 08-17-2009, 12:54   #7 (permalink)
Member: 714722
Thanks Meter: 33
same withe me please any solution
thanks
Old 08-17-2009, 18:43   #8 (permalink)
Member: 4458
What is same?
Regards,Vygis
The Following User Says Thank You to vygism For This Useful Post:
Old 08-31-2009, 23:39   #9 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
normally just flash it and after unlock it, for flashing using Download mode, not power on phone, because if the phone is power on in normal mode, some time fllasing don't finish, and give you error.
Best Regards,
JAVA Good.
Old 08-31-2009, 23:55   #10 (permalink)
Member: 474339
Thanks Meter: 44
brother..first try to explain ur problem in details..
just full flash the fone and then unlocked..100% tested and works
Old 09-01-2009, 00:12   #11 (permalink)
Member: 181405
Thanks Meter: 249
LG Qualcomm phones from H3G network has different "MEDIA" files,depending from
country-region.If you will write flash with not correct region-phone will show
"Unavailable MEDIA file".If flash file,which you want to write to phone has different
region from you phone's country,before flash writing check "Change Region" and select
needed country-region.
HELP!!HOW to repair the ku990 "unavailable otp block" by vygis 北京混混 VygisToolbox 25 06-24-2011 10:21
how to repair ku990i yellow screen (refreshing) 4given4gotten FuriousGold 1 03-29-2010 17:43
Can anyone know how to repair THE LCD circuit of V3 (moto)excluding main PCB board dread_mastah Motorola Hardware Repair 0 01-09-2010 17:42
Help how to disable the Pen Calibration of N95 Single sim Dj King Infinity-Box 6 08-09-2008 22:56
How to repair the IMEI to ORIGINAL on KU990 & KE990 when damaged by free solutions AlexG LG 14 05-19-2008 00:33
Page generated in 0.26694 seconds with 10 queries
