Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 11-26-2009, 12:18   #1 (permalink)
DOUHAL's Avatar
Member: 43036
Sonork: 100.62160
Post How to enter my Unlock Code on LG Electronics / UPDATABLE ..
I saw in many posts in this forum the same question i post this thread for helping all our USERS VYGISTOOLBOX
Model : LG A133
- power phone ON
- type 2945#*133# to enter unlock menu
- enter needed unlock code
Model : LG C1100
- First you must put in an allowed simcard, then :
- type 2945#*1201#.
- Goto Menu/Settings/Security Settings/Sim Locks
- Select 'Locktype'/Deactivate and Enter the code.
Model :lg F2250
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and press OK.
Model :LG GB130
- put original sim card type 2945*#20001# enter menu setting security desactived sim lock
Model : LG GD510POP
- Power ON your phone with SIM Card that the phone is locked to
- Type 2945#*510# from the dialer
- Enter UNLOCK CODE
- Press OK
- Device is now unlocked.
MODEL GS290
- power phone ON without SIM
- type 2945#*290# to enter unlock menu
Model GS390
How to enter unlock code LG GS390
1- Power phone ON with a non-accepted SIM card
2- Select Unlock
3- Phone will indicate phone is locked
4- Press Yes
5- Dial unlock code and press OK
6- Phone will ask for the unlock code again, dial same code and press ok
7- Phone is unlocked
Model : LG GT505
- type 2945#*505# to enter unlock menu
- enter unlock code
Model : LG GB250
- type 2945#*71001# to enter unlock menu
- enter unlock code
Model : LG GW520
- enter unlock code !
You can try and reset from phone test menu - 1809#*520# and later "Factory reset"
Model : LG GW620R
- Type 2945#*620# from the dialer
- Enter UNLOCK CODE
- Press OK
- To RESET : Try 3845#*620# and later "Factory reset" and "Reset UserData".
Model : LG KB770
1. Power on phone with original SIM card
2. Type 2945*#770#
3. In the menu that appears select Sim unlock
4. Enter supplied unlock code
5. Your phone is unlocked
Model : LG KP170
1 - Switch ON your phone with a T Mobile Sim inserted
2 - Press telephone icon at bottom of screen to bring up the phone keypad
3 - Then compose : 2945#*170#
4 - A menu will pop up, select Unlock Usim
5 - Then Select Network Lock
6 - Enter your unlock code and press ok (you only have 10 attempts)
7 - The phone will then reboot and the unlock is complete.
Model : LG KG800 or TG800.
1) Power ON your phone with different SIM Card then the phone is locked to
2) Type 2945#*7101#
3) Go to Menu "Setting"
4) Go to Menu "Security"
5) Go to Menu "SIM Lock"
6) Go to Menu "Network"
7) Go to Menu "Deactivate"
8) Enter Unlock Code
9) Device is now unlocked.
Model: LG CU-515
1.Put a SP-locked sim in the phone, phone say invalid smart chip
2.Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Phone will be unlocked!
Model : LG TE365
2. Type *#0001#code#
3. Your phone is unlocked
Model : LG CT810 (Incite)
2. Type 2945#*810#
Model : LG CB630 (Invision)
1) Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2) Dial this into the LG Incite's phone menu
3) *#865625#
4) Press CALL.
5) It should you ask you for the code.
Model : LG U830
1. Have your unlock code handy.
2. InserI a 3 SIM card in the phone and switch power on.
3. Enter the following key sequence 94471877#*#
4. Select the option ‘unlock USIM’.
5. Select the option ‘network unlock’
6. Enter your unlock code.
7. Handset should now display ‘network unlock success’.
8. Handset will now restart.
Model : LG KF300
1. Put wrong simcard
2. Phone alert 'insert correct card'
3. Right under in screen you see deblokkeren (dutch)
4. Click on it en click 'Network lock off'
5. Insert code!
How to enter unlock code LG-MG160 MG161 KG270 KG271 KG275 KG276 KG278 KG288 KG370 KG375
Phone is locked but does not as to enter code:
1. insert any wrong Sim-Card in phone
2. you will see on LCD: "insert correct sim"
3. type unlocking code and press Call "Green" button
4. wait for few seconds - phone will restart and unlocked
Model : LG KP100
1. Insert original sim card and turn phone on.
2. Enter 2945#*20001#
3. Sim unlock mode pop up .
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Model : LG KF755d
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*755# (or 2945#*750# if 1st option doesn't work)
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete
Model : KG245
How to Unlock LG KG245 (Vodafone Australia):
1. Insert a Vodafone Australia working SIM card.
2. Ensure the phone is charged and then switch the phone on.
3. Optional Step: If the SIM card has a PIN, enter your PIN number
4. Wait for the phone to power up then enter 2945#*7101#
5. Select Menu , then go to Settings > Security > SIM Lock > Network
6. Select Deactivate and enter the 8-digit unlocking code provide for your handset.
7. The handset will be unlocked automatically and will display “Done”. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
Model : LG Incite CT-810
- Insert a SIM from the original network
- 2945#*810# will show the unlock menu
- Enter unlock code
Model : LG KP265
1 - Use Original SIM to switch ON the Phone.
2 - Compose 2945#*265#
3 - Then go to MENU > SETTINGS > SECURITY
4 - Then go to SIM LOCKS > NETWORK > DESACTIVATE
5 - ENTER NCK (your Unlock Code)
Model : LG ME550
2 - Compose 2945#*71101#.
3 - Menu will appear, go to settings > security > sim lock
4 - Enter NCK ( Unlock Code ) and press OK.
Model : LG TU915
- Switch ON your phone with an allowed SIM Card
- Then compose: 2945#*9701#
- It should you ask you for the code.
OR
Enter *#865625# then enter your 16 digits code.
Model : LG KF390 and KF390q
1) Insert a SIM Card from the network the mobile is locked to and turn it on
2) Insert the following sequence *#865625#;
3) Select 'Unlock USIM'
4) Select 'Network Lock'
5) Insert the unlock code
6) Select ok. Done!
Model : LG G910 :
1. Insert an invalid simcard and turn phone on.
2. Insert PIN
3. Phone says \"Invalid sim card\"
4. Select \"Emergency calls\"
5. Enter 2945#*71001#
6. Sim unlock mode pop up
7. Select netlock
8. Enter your 16-digit unlock code and press ok
9. The phone will then reboot and the unlock is complete.
Model : LG *****, KE850 :
1. Switch the telephone on with Original SIM card inside.
2. Enter SIM pin if required.
3. Enter 2945#*8501# and press the call button (middle button bottom of the screen).
4. SIM unlock mode will appear on screen.
5. Enter unlock code
6. Select Reboot.
7. Switch phone off, and then turn back on again. Phone is now unlocked
Model : LG CT810
1. insert original sim card and turn phone on.
2. Enter 2945#*810#
3. A menu will pop up, select sim unlock
Model : LG VU CU915 & CU920 (Vu)
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2. Enter *#865625# then the 16 digit unlock code
3. Device should say: Network Lock Deactivated
4. Phone may automatically reboot and is now unlocked !
Model : LG U310
1. Turn ON the phone without SIM Card :
2. Enter 815118#*#
Model : LG KC550, KS360, KP230, KP500, KP501, KP270, KM900, KM500, GT810, GC900, GT360
2. Enter 2945#*71001#
Model : LG KF700 (aka LG Virgo)
2. Enter 2945#*700#
Model : LG KC910, KF910 (aka LG *****)
2. Enter 2945#*910#
Model : LG KF750
2. Enter 2945#*750#
Model : LG KF600
Model : LG U970
2. Enter 2945#*970#
3. A menu will pop up, select Unlock Usim.
4. Select Network Lock.
5. Enter the unlock code and ok.
Model : LG U300
1 - Switch ON the phone with Accepted SIM Card (from Original Network Provider)
2 - Enter Code : 815118#*#
3 - then phone will ask to enter NCK
Model : LG C2000:
1) Insert non-Cingular SIM card
2) Power on the handset - phone will display "phone restricted"
3) Select "Cancel" - phone will display "phone restriction code"
4) Enter the SIM Unlock code
5) Select "OK" - the handset is now successfully unlocked
Model : LG KU990 Viewty & KE990
3. Enter 2945#*990#
6. The phone will then reboot and the unlock is complete.
or
1. Without sim phone power "ON"
2. Hold "camera" + "lock" button
3. You will get key pad write 2945#*990#.
4. Press active code.
5. Your cellphone will be restart
6. Turn off cellphone and insert your sim (internation sim)
7. Enjoy your unlocked phone !
Model : LG TU515
To enter unlock code for LG TU515 should:
1. Power on your LG phone with the original SIM card in.
2. Enter *#865625#
3. A menu will pop up, select SIM Unlock or network lock.
4. Enter the NCK unlock code
Model : LG TU720 - LG CU720 (Shine)
1) Power ON your phone with not allowed sim card (one that didn't come with the phone)
2) Type *#865625#
3) the phone will ask you to input the unlock code twice, just input the unlock code
4) Device is now unlocked
Model : LG TU750
How to Enter Unlock Codes on LG TU750 Secret:
2. Enter *#865625#
3. A menu will pop up, select USIM unlock
4. Select Network lock
6. Enter the unlock code again
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone;
2) The phone display: Invalid Smart Chip
3) Power on handset
4) Select "Cancel" - phone displays "phone restriction code"
5) Enter the unlock code (8 digit code*)
6) Select "OK’" - the handset is successfully unlocked
Model : LG GR500 (Xenon)
1) Insert not-allowed SIM card
2) Power on the handset- phone will display "phone restricted"
4) Enter the SIM unlock code
or
2. Enter 2945#*9701#
or
After turning on your mobile phone, press: *#865625#
Press Yes to continue.
Enter the 16 digit Subsidy Unlock Code
Enter the 16 digit Subsidy Unlock Code, again.
Device should say: “Network Lock Deactivated”
Model : LG CU320
1) Power on the handset
2) In Idle screen, input the special code "277634#*#".
3) Enter the SIM Unlock code
4) Access the submenu "SIM Test" in Phone Test Mode.
5) Input the special code "2945#*#".
6) Access the submenu "SIM Unlock" which is just activated after the special code.
7) Input the 8-digit Unlock code in the "Enter unlock code" input screen.
8) It will be unlocked.
Model : LG CU400 & CU405
1) Insert non-Cingular SIM card"
2) Power on the handset - Phone will display "Invalid SmartChip".
3) Enter 159753#*#
4) Enter the 8 digit SIM Unlock code
5) Select "OK".
6) The handset will be unlocked.
Model : LG CU500
1) Insert non-Cingular SIM card.
2) Power on the handset. Phone will display "Invalid SmartChip"
3) (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4) In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5) Enter the 8 digit SIM unlock code
6) Select "OK"
7) The handset is now successfully unlocked.
Model : LG CU515, CU575 (Trax)
1) Put a non-Cingular sim in the phone
2) Phone says invalid smart chip
3) Now enter *#865625# then select option 1 and then again select 1
4) Enter your 16 digits code
5) Device should say: Network Lock Deactivated
6) The handset is unlocked.
Model : LG U8150
1 - Switch ON your phone with a NOT Allowed SIM Card,
2 - Compose : 2, 7, 7, 6, 3, 4, #, *, #,
3 - Go to menu "SIM Lock",
4 - Enter the Unlock Code we send to you.
Model : LG U400
1. Insert the network SIM in the handset which has given u the LG U400.
2. Enter 2945#*88110#.
3. The phone will then prompt 'Unlock sim'. Press OK.
4. The phone will then prompt 'Network Unlock'. Press OK.
5. The phone will then prompt- 'Input Network Control Key'.
Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code.
6. It should give you the message Success.
7. Come back to the main screen and Enter 2945#*88110#.
8. The phone will then prompt unlock sim. Press OK.
9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code.
10. Then press OK
Model : All other model
1 - Switch ON your phone with an Allowed SIM Card,
2 - Then compose :
2945#*5101# - (if you have a LG 510w)
1945#*5101# - (if you have a LG 1200 & B1200)
2945#*5221# - (if you have a LG 5200 & 52200)
2945#*5301# - (if you have a LG 5300)
2945#*5401# - (if you have a LG 5400)
2945#*70001# - (if you have a LG 7020)
2945#*7101# - (if you have a LG 7100)
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
2945#*70001# - (if you have a LG7250T)
2945#*2201# - (if you have a LG C2200)
2945#*5301# - (if you have a LG T5100)
2945#*3311# - (if you have a LG C3310)
3 - Go to "Menu" and then to "Settings",
4 - Then select "Security",
5 - To finish select "Network Provider" and select "Desactivate"
6 - Enter the Unlock Code we send to you.
Model : To Classify
For the next models u must to insert the original SIM:
LG C3100 press 2945#*3101#
LG C3380 press 2945#*7101#
LG F2300 press 2945#*7101#
LG KE260 press 2945#*2601#
LG KE970 press 2945#*9701#
LG KG120 press 2945#*1201#
LG KG220 press 2945#*1201#
LG KG240 press 2945#*3311#
LG KG280 press 2945#*7101#
LG KG290 press 2945#*7101#
LG KG800 press 2945#*7101#
LG KU250 press 2945#*250#
LG KU380 press 2945#*380#
After that will appear an secret menu,go to settings-security- sim lock ,enter NCK and press OK.
For next models insert one SIM ,not the original SIM:
LG KU311 press 815118#*#
LG KU800 press 82652#*#
LG L600v press 815118#*#
LG U8150 press 277634#*#
LG U8210 press 277634#*#
LG U8500 press 277634#*#
LG U400 press 2945#*88110#
LG KC550 press 2945#*71001#
LG KU580 press 2945#*580#
LG KT520 press 2945#*520#
LG KF750 press 2945#*750#
LG KF600 press 2945#*71001#
LG KG275 press 2945#*20001#
LG KS500 press 2945#*500#
LG KP270 press 2945#*270#
LG KF240 press 2945#*240# or 2945#*2401#
Enter NCK and press OK.
Model : LG S310
- type 2945#*310# to enter unlock menu
Best Regards DOUHAL
Old 03-21-2011, 12:45   #2 (permalink)
DOUHAL's Avatar
Member: 43036
Sonork: 100.62160
HOW TO RESET UR LG Phones / UPDATABLE
* LG KS20,MS20,MS25 passwords reseting :
- power OFF phone
- press and keep "Volume down" + "Send(Call)" + "Power ON" buttons together
- LED in upper right corner of phone must turn to red,blue and green
- release pressed buttons
- phone must start ON and ask for reconfiguration
* LG GM730, GM735 and GM750 hardware reset:
- power OFF phone
- press and keep "Volume down" + "Camera" + "Power ON" buttons together
- release pressed buttons, when Windows screen appears
- wait few minutes until phone will ask for reconfiguration
* LG CT810,CT815,GT810 hardware reset:
- power OFF phone
- release pressed buttons, when splash screen appears
* LG E900, LG C900 hardware reset:
- power OFF phone
- press and keep "Volume up" + "Volume down" + "Camera" + "Power ON" buttons together
- release pressed buttons, when screen with "COLD BOOT" appears
* LG GS155 reset:
-1809#*155# and later "Factory reset"
* LG L704i,L705i,L705iX and L706ie user code reseting:
- type on phone keyboard #17320508*# to enter phone test menu
- select "Factory reset"
* LG P500-509 Reset : To remove phone lock is needed to reset phone - for this press "Home"+"Volume up" + "Power ON" till you will see Android symbol
Regards/Douhal
The Following 8 Users Say Thank You to DOUHAL For This Useful Post:
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Page generated in 0.36928 seconds with 11 queries
