06-14-2006, 10:15 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | Then you did something wrong Check cable again and also keep pressed power ON button till bootloader will be uploaded to phone,when you will see "Reading info ...",you can release power ON button. Regards,Vygis |
06-14-2006, 11:30 | #6 (permalink) |
Member: 4458 Status: Offline Thanks Meter: 25,853 | Something strange here,anyway please try to change baudrates to 115 kb and also other-try to connect phone also like C3300 for example.And last question-this KG800 is from China,or from Europe? Regards,Vygis |
06-14-2006, 11:37 | #9 (permalink) | |
Freak Poster Join Date: Dec 2005 Location: china
Member: 207686 Status: Offline Thanks Meter: 22 | Quote:
yes i keep power on button | |
06-14-2006, 11:42 | #10 (permalink) |
Member: 4458 Status: Offline Thanks Meter: 25,853 | Ok-then last try-try to connect it via ComPort-right RJ45 connector on box. If wont help-at this moment not have more ideas,except to buy this phone from you and look what is wrong with it. Regards,Vygis |
06-14-2006, 13:39 | #14 (permalink) |
Member: 4458 Status: Offline Thanks Meter: 25,853 | Looks that some problems with cable-I don't have any ideas more.Btw,how you made it-my own I made using handsfree connector,inside it has little pcb. Regards,Vygis |
How to Flash KG-800 with infinity | abellcell | Infinity-Box | 0 | 06-09-2008 05:54 |
flash kg 800 | Ramicom | VygisToolbox | 3 | 06-04-2008 22:42 |
Kg-800......kg-90???? | KingKronik | FuriousGold | 3 | 11-18-2006 17:54 |
Difference between KG-800 and KG-90??? | KingKronik | VygisToolbox | 1 | 11-18-2006 01:49 |
Need arabic flash for kg 800 chocolate | pearsonjohnboy | FuriousGold | 1 | 11-04-2006 16:04 |
