06-18-2009, 12:43 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: URL - UnlockRepairLandia Age: 41
Member: 236218 Status: Offline Thanks Meter: 35 | ke500 broken imei after flash |
06-18-2009, 23:13 | #3 (permalink) | |
Freak Poster Join Date: Jul 2004 Age: 44
Member: 71526 Status: Offline Thanks Meter: 48 | Quote:
What FW has been inside before flashing, what state of phone has been before flashing (fully working, white screen, hangs on LG, why do U flashed phone ? for language change??) did U tested phone before ? many phones flashed and no such problems occured.. Br Shadowman | |
06-19-2009, 09:16 | #4 (permalink) |
Member: 236218 Status: Offline Thanks Meter: 35 | Yes phone is working, but I cannot restore imei. I was flash the phone for lang changing, phone before work ok. For imei options need connect powered om phone to box or to usb? I connect to box, but cable is from microbox, maybe there is problem... I was try unlock, bet still not writing, repair eeprom button is inactive too. Phone type : LG-KE500 Phone IMEI : Unknown Flash ID : EC78 Flash type : Samsung NAND 64 Mb current sw: ke500p64 07-v10w previos ver: ke500p64......v10g first time I flash with vygis to ver 10v and lost imei, second time flash with original flasher to 10w Last edited by mail0; 06-19-2009 at 09:25. |
06-19-2009, 20:07 | #6 (permalink) | |
how I know for LG IMEI restore/change is via AT commands, so it uses different protocol. U must have correct cable and phone must be connected via serial connection and powered ON. | |
06-19-2009, 20:14 | #7 (permalink) | |
very strange situation.. but who knows.. some members posted about handsfree allways connected after flashing, but it has been dammaged by wrong cable.. some times flash chip has too many dead sectors (nand flash) and cannot be remapped to good sectors or smth. thats why by flashing new sw version U can get a brick | |
06-20-2009, 01:51 | #8 (permalink) |
Member: 236218 Status: Offline Thanks Meter: 35 | no no no, it is a very normally that phone get default imei after flash and unlock procedures, I know this with working with different tools, only important question is how to restore original imei now |
06-20-2009, 01:55 | #9 (permalink) |
Member: 236218 Status: Offline Thanks Meter: 35 | I cannot restore via serial cable, plz share AT commands for imei changing also you must present right sable schematic for performing this operation as I say before, I use cable from microbox set and there is available operations only in boot mode, maybe some vires is not connected for normal mode operations.... |
06-20-2009, 09:50 | #10 (permalink) | |
************************KE500,ME550 pinout for flashing*************************** keybord up 18.............1 17 - RX (data to phone) 16 - TX (data from phone) 1,4,14,18 - GND For working with service functions -Read IMEI,Write IMEI, Phone Reset - use KG800 cable. ****************MG160,KG270,KG370,KG320,KG800 pinout****************************** keybord up 18.............1 7 - RX (data to phone) 6 - TX (data from phone) 1,4,14,18 - GND Br Shadowman | |
Ke500 White Display After Flash | MORRISGSM | VygisToolbox | 7 | 07-16-2009 20:40 |
Ke500 White Lcd After Flashing | jacekchec | VygisToolbox | 3 | 02-04-2008 08:30 |
Twister Team Imei?????? After Flash | mas comm | Twisterflasher | 2 | 06-05-2005 07:32 |
6600 with imei = ?????????? after flash!!! | et.com | WD2 & APE (Symbian Phones) | 8 | 04-22-2005 09:48 |
