05-23-2008, 08:55 | #2 (permalink) |
Junior Member Join Date: Jan 2008
Member: 688538 Status: Offline Thanks Meter: 4 | Did'nt think this was such a difficult question, anyway I have found the answer myself, I always thourght forums were to help. Have fun. If anyone needs to know the answer PM me and I will help. Phil |
05-23-2008, 16:26 | #3 (permalink) |
Member: 688538 Status: Offline Thanks Meter: 4 | Hi, Having found the required software I needed to perform the “Temporary Unlock” On the LG U890, I carried out the Flash using Vygis. All went well and completed ok. I followed the help instructions as below by inserting a 3g sim card, powered up phone, plugged in LG charger, phone showing charging, “Menu” -- “Tools” – “Unit converter”. Leaving the charger on the phone I removed the battery, 3g sim card and within 5 seconds put in T-Mob sim card, replaced the battery and waited for the phone to power down and reboot. After 10 minutes the phone never powered down or rebooted. I removed the charger and waited, nothing, I removed the battery and it powered down, replaced the battery and pressed power up button. The phone powered up but the screen says “USIM locked” Any one able to help please. Phil Quote from Vygis Toolbox….. Temp unlocking : - U300,U880,U890 and U900 can't be unlocked permanently at this moment. For temp. unlocking, flash phones with flash from support(flash in name must have string "TEMP UNLOCK", if your phone's region differs from flash region, in "Flasher" section check "Change Region X=UK" and select needed region. - after flashing do next : for models U300 and U890 (64k and 128k SIM supported) : a) insert original 3G card to your phone b) power ON phone and connect charger or USB cable to it c) phone must show charging d) go to "Menu"-"Tools"-"Unit converter" and select it e) fast change original 3G card with your SIM card(your SIM card must be without PIN) f) wait until phone will reboot |
can i Direct Unlock or patch Unlock LG U880 or LG U890 Plz help | mujahid_ali | Multi-box LITE | 4 | 10-20-2008 13:47 |
samsung p910 and lg u890-900 | pjk1980 | NSPRO | 8 | 09-08-2006 12:09 |
LG u880 - Lg u8500 - LG u900 - Lg u890 Unlock ?!?! | Dengel | FuriousGold | 6 | 07-22-2006 00:55 |
