12-13-2006, 19:02 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 213805 Status: Offline Thanks Meter: 1 | KG800 always error when connecting Here is a log of what happens: Loading boot... Boot loaded OK Flash ID : 984A Flash type : Toshiba - 16 Mb Second flash ID : 9849 Second flash type : Toshiba - 16 Mb ----------------------------------------------- Reading phone info ... Operation failed I have tried using earlier version (1_65SC), but still same problem. I have also tried with 3 working cables (i know this because i use them with Furious Gold with no problems), and still same problem. Anyone else having this issue? or know how to fix? All drivers are installed properly, and reads other phones fine. |
12-15-2006, 10:31 | #4 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | Ok, i just had same error few minutes again, and here how to fix it: When you start the software, if you try to adjust the port speed (right , up, empty field), you cannot. BUT, after trying one time and giving error, just go to that field, set a speed like 460 or 920kb.s and then try again. Don't forget to KEEP THE POWER ON BUTTON HOLD, UNTILL ALL THE PHONE INFORMATION IS DETECTED. Then you can also unlock the phone smoothly. regards, Gobi |
Always error when cconnecting to server " NOT CONNECTED " | mujahid_ali | SAGEM JTAG UNLOCKER | 4 | 08-17-2009 16:21 |
Nec 228.313,616 always Error in connection | Irfangk786 | FuriousGold | 23 | 07-12-2007 14:50 |
"Client/server mismatch detected." Always error when connecting to the server! | ReyTech | Cruiser Suite | 5 | 11-13-2006 16:11 |
U8120 V101 Always Error when unlocking | tical | Redbox | 3 | 02-12-2005 21:49 |
always error when unlocking | blutac | Smart-Clip | 6 | 07-11-2004 02:00 |
