08-08-2009, 06:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Hungary Age: 42
Member: 22902 Status: Offline Sonork: 100.64924 Thanks Meter: 88 | KM900 flash error ---------------------------------------------------------- Loading primary loader ... OK Loading secondary loader ... OK Changing baudrate ... OK Loading certificate ... OK ---------------------------------------------------------- Reading phone info ... OK ---------------------------------------------------------- Writing flash from file : KM900AT-00-V10b-EEU-XXX-MAY-05-2009_EN_IT_GER_FR_ES_GR_NL_PT_SW_DA_RO_TR_HU_SLO_C Z_CRO_BUL_PL_SK_FIN_NO_SERB_EE_KZ_LV_LT_RU_UKR.fls ---------------------------------------------------------- Checking flash file ... OK Extracting flash files ... OK Found 10 files for writing Writing flash : ../../../wou_build/OPERA_EUROPE_OPEN_RELE ASE/MPEH_OPERA_EUROPE_OPEN.dsp ... OK Writing flash : MPEH_OPERA_EUROPE_OPEN.eep ... OK Erasing dynamic eep area ... OK Writing flash : MPEH_OPERA_EUROPE_OPEN.fls ... Writing part 1 ... OK Writing part 2 ... OK Writing flash : OPERA_EUROPE_OPEN-CUST.dfat ... OK Writing flash : OPERA_EUROPE_OPEN-ROOT.dfat ... OK Writing flash : OPERA_EUROPE_OPEN-USER.dfat ... OK Writing flash : psi_large_block_16_bit_paging.flb ... OK Writing flash : slb_large_block_16_bit_paging.flb ... OK Writing flash : ua_large_block_16_bit_paging.flb ...l Operation failed Can't load certficates Now the phone show only "version mismatching" |
08-08-2009, 09:37 | #2 (permalink) |
Member: 22902 Status: Offline Sonork: 100.64924 Thanks Meter: 88 | same error with another flash file: Please power ON phone ---------------------------------------------------------- Loading primary loader ... OK Loading secondary loader ... OK Changing baudrate ... OK Loading certificate ... OK ---------------------------------------------------------- Reading phone info ... OK ---------------------------------------------------------- Writing flash from file : KM900AT-00-V10h-CIS-XXX-MAR-19-2009_EN_IT_GER_FR_ES_GR_NL_PT_SW_DA_RO_TR_HU_SLO_C Z_CRO_BUL_PL_SK_FIN_NO_SERB_EE_KZ_LV_LT_RU_UKR.fls ---------------------------------------------------------- Checking flash file ... OK Extracting flash files ... OK Found 10 files for writing Writing flash : ../../../wou_build/OPERA_EUROPE_OPEN_RELE ASE/MPEH_OPERA_EUROPE_OPEN.dsp ... OK Writing flash : MPEH_OPERA_EUROPE_OPEN.eep ... OK Erasing dynamic eep area ... OK Writing flash : MPEH_OPERA_EUROPE_OPEN.fls ... Writing part 1 ... OK Writing part 2 ... OK Writing flash : OPERA_EUROPE_OPEN-CUST.dfat ... OK Writing flash : OPERA_EUROPE_OPEN-ROOT.dfat ... OK Writing flash : OPERA_EUROPE_OPEN-USER.dfat ... OK Writing flash : psi_large_block_16_bit_paging.flb ... OK Writing flash : slb_large_block_16_bit_paging.flb ... OK Writing flash : ua_large_block_16_bit_paging.flb ... Operation failed This is bug in software (tried 1.51 and 1.53), or bad flash file, or problem with phone? |
08-08-2009, 15:27 | #3 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | Actually old versions not supports KM900 flashing-download LGI_1_54SC from supports-it already flashes KM900-you even can flash it via USB Via USB it takes about 12 minutes only. Regards,Vygis |
The Following 6 Users Say Thank You to vygism For This Useful Post: |
08-08-2009, 17:51 | #4 (permalink) |
Member: 22902 Status: Offline Sonork: 100.64924 Thanks Meter: 88 | Thanks man, succsessfully repaired with 1.54 Here is the log: Connecting phone - connect USB cable to phone, phone must be OFF and without battery ... Driver connected, connecting phone ... OK ---------------------------------------------------------- Changing baudrate ... OK Setting bus ... OK Loading certificate ... OK ---------------------------------------------------------- Reading phone info ... OK ---------------------------------------------------------- Writing flash from file : KM900AT-00-V10h-CIS-XXX-MAR-19-2009_EN_IT_GER_FR_ES_GR_NL_PT_SW_DA_RO_TR_HU_SLO_C Z_CRO_BUL_PL_SK_FIN_NO_SERB_EE_KZ_LV_LT_RU_UKR.fls ---------------------------------------------------------- Checking flash file ... OK Extracting flash files ... OK Found 10 files for writing Writing flash : ../../../wou_build/OPERA_EUROPE_OPEN_RELE ASE/MPEH_OPERA_EUROPE_OPEN.dsp ... OK Writing flash : MPEH_OPERA_EUROPE_OPEN.eep ... OK Erasing dynamic eep area ... OK Writing flash : MPEH_OPERA_EUROPE_OPEN.fls ... Writing part 1 ... OK Writing part 2 ... OK Writing flash : OPERA_EUROPE_OPEN-CUST.dfat ... OK Writing flash : OPERA_EUROPE_OPEN-ROOT.dfat ... OK Writing flash : OPERA_EUROPE_OPEN-USER.dfat ... OK Writing flash : psi_large_block_16_bit_paging.flb ... OK Writing flash : slb_large_block_16_bit_paging.flb ... OK Writing flash : ua_large_block_16_bit_paging.flb ... OK Writing flash : a250_single_image.fls ... OK ======== Process completed ======== Operation time - 0:12:48 WBR |
The Following User Says Thank You to qwerthj For This Useful Post: |
km900 flashing error | hugmax | VygisToolbox | 1 | 03-22-2010 05:22 |
km900 flashing error | dheeraj_b | VygisToolbox | 1 | 02-05-2010 11:02 |
KM900 Flash Error! | AlexG | Z3X-Team Products | 1 | 11-24-2009 19:39 |
KM900 flash error | gazsy | Z3X-Team Products | 8 | 10-31-2009 00:08 |
