Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 06-06-2009, 13:53   #1 (permalink)
RCB Telecom's Avatar
Member: 972420
Sonork: manole
ku250 how to flash in vygis box,help,because after unlock no signal.....
try to seting no lucky,try repair nvm no lucky also..... help vygis team..............
Old 06-06-2009, 13:58   #2 (permalink)
Member: 972420
Sonork: manole
im newbie this box,b4 unlocking,i just forgot back up nvm,this my mistake,unlock success but no signal,this problem can revived,i need solution mr vygis,help..........i need your advise about my fault to unlock ku250......
Old 06-07-2009, 22:55   #3 (permalink)
Member: 4458
If you flash from normal mode-all backups are created automatically-for them writing is needed only to press "Write NVM" and software automatically will redirect you to folder where your NVM backups are.If NVM backup not exist-also no problem,for such problems exist button "Repair NVM".
Regards,Vygis
And advice for beginners-read at first "Flasher help.txt" and "Unlocker file.txt" file-this will help for you much.And also other-use search function in our section of forum-I think,that 99% of problems can be solved using search.
Old 06-11-2009, 02:48   #4 (permalink)
Member: 972420
Sonork: manole
after unlock ku250 ,but no signal all network,im going to do first repair nvm first,repair nvm and write orig nvm but no lucky,i tried also flashing last option but no lucky also,b4 unlock i just read forum how unlock properly,my question is this problem corrupted nvm files from ku250 can revived this cases?mr vygis?i need full back up on smart on ku250 nvm files tested,mr vyvis?help
Old 06-11-2009, 21:51   #5 (permalink)
Member: 4458
At first unlock not touches NVM-all unlock goes via so called OTP area in phone.In your case I would say,that something is wrong with phone hardware if even "Repair NVM" not helps.Anyway you all time can return tp previous state like phone was before unlocking-press "Write backup" and you will be redirected to folder where your SP backup is-write it and phone will become same like was before.But as I said before-here looks to hardware problem.
Regards,Vygis
P.S.One more idea-try to change IMEI-maybe it is blocked.
ks360 how to flash in vygis??? nans1981 VygisToolbox 0 02-17-2010 08:16
ku250 how to flash in vygis box,help,because after unlock no signal..... RCB Telecom VygisToolbox 0 06-06-2009 13:29
3g after unlock no signal plz help puffy111 iPhone ,iPod & iPad (Apple Inc. Products) 1 01-03-2009 14:25
L1400I after unlock no signal in middle east mobayk LG 3 09-22-2008 08:38
v3xx after unlock no signal help ahmertelecom Smart-Clip 1 10-13-2007 10:04
Page generated in 0.24592 seconds with 11 queries
