07-16-2009, 17:18 | #1 (permalink) |
Junior Member Join Date: Aug 2005 Age: 42
Member: 166608 Status: Offline Thanks Meter: 0 | Ku990 flash problem I seem to have a strange problem, I have tried flashing a Ku990iGo and a Ku990go and both have the same error as pasted below. I've only just started to use vygis and it has direct unlocked handsets including the one noted below, but when I try to flash the handset it gets to no more than 5% writing AMSS then it gives a warning saying flash not completed and to put the handset into emergency download mode, but no matter what I do it wont continue and says operation failed, and now both handsets power on and go to a yellow screen with refreshing written in top left of screen. I've searched this forum but don't see anything the same. Hopefully someone can help or has had the same problem? Many thanks Phone type selected : KU990GO IMEI : 354935-xxxxxxxxxxx Bluetooth Addr : 00:21:FBB:B3:FD Phone version : KU990GO-MSM6280-V10i-AUG-15-2008-XX Compilation info : Aug 15 200820:11:43AUG 15 200817:00:00KU990GO Connecting ... OK Connected in NORMAL MODE Flash ID : 98CA Flash type : toshiba_tya000bc00bogg Flash size : 0D860000 Flash pages count : 0001B0C0 Flash page size : 00000800 Flash block size : 00020000 ---------------------------------------------------------- Writing flash from file : KU990GO_V10a-O2-GB_EN_IT_GER_FR_ES_GR_NL_PT_SW_DA_RO_TR_HU_SLO_CZ_ CRO_BUL_PL_SK.crc Checking flash files ... OK ---------------------------------------------------------- Reading NVM backup ... OK NVM backup saved to file : NV_KU990GO_354935-02-915625-3_2009_7_16_17_6.nv2 Erasing MODULE,please wait ... OK ---------------------------------------------------------- Writing PARTITION TABLE ... OK ---------------------------------------------------------- Writing AMSS ... Operation failed |
07-17-2009, 14:20 | #4 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | Actually hard to say where problem is anyway I have few questions-USB cable is used? LG Modem drivers from my support sites are installed? Regards,Vygis |
07-17-2009, 14:59 | #5 (permalink) |
Member: 166608 Status: Offline Thanks Meter: 0 | Tried 2 cables, both genuine lg usb cables supplied in box with Ku990, also uninstalled and re installed drivers several times, the furthest it gets is to 8% of flashing amss, it's like it freezes but never at a certain point, more like it times out or something? Do I need a special cable? As it works to unlock and always performs the flash process perfect until the amss flash then it fails I am also going to set up another pc and try, just incase it's the pc, it's just strange that no one else has experienced this! I thought it was my mistake or error but it's hard to understand why it works well, but only to that certain point! Is there any extra settings that need to be changed? I can provide a screenshot of the error? |
07-17-2009, 17:24 | #6 (permalink) |
Member: 4458 Status: Offline Thanks Meter: 25,853 | Actually I also can't say where is problem-noone more have such problems seems.Usually such behaviour can be only if battery is not charged-this is from my own practice. Regards,Vygis |
The Following User Says Thank You to vygism For This Useful Post: |
07-18-2009, 17:04 | #7 (permalink) |
Member: 166608 Status: Offline Thanks Meter: 0 | Tried on different pc and works fine!!! Problem solved, might be some driver conflict, but seemed very strange for it to work only to a certain point, normally works 100% or not at all!!! Thank you Vygis please close or lock this thread |
LG KU990 Flash problem | asson | Z3X-Team Products | 9 | 08-30-2009 12:42 |
KU990 Flash problem | mpm07 | LG | 2 | 09-29-2008 21:11 |
Ku990 flash problem | sources | VygisToolbox | 1 | 06-18-2008 09:42 |
Ku990 Flash Problem Help | davilixian | FuriousGold | 1 | 03-29-2008 04:56 |
