03-18-2015, 15:12 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | LG E455 Flash erro: No ACK after write block command Code: Phone type : LG-E455 Phone IMEI A : 355672-05-484***-1 Phone IMEI B : 355672-05-484***-9 Phone BT address : 58:A2:B5:61:57:30 Phone version : LGE455AT-00-V10a-IND-XX-FEB-14-2013+0 Connecting phone - connect USB cable to phone, phone must be OFF - if you can't connect using micro USB cable - use P999 cable (with 910k resistor) ... Opening USB Port (COM120) ... OK ---------------------------------------------------------- Loading primary loader ... OK Executing loader ... OK Reading flash info ... OK ---------------------------------------------------------- Reading phone info,please wait ... OK ---------------------------------------------------------- Writing flash from file : LG-E455_LGE455AT-00-V10d-CIS-XX-MAY-21-2013_EN_RU_UKR_KZ_RO_KOR.crc Extracting flash files, please wait ... OK ---------------------------------------------------------- Getting flash file params ... OK Formating ANDROID ... OK Formating CACHE ... OK Formating USRDATA ... OK Getting bootloader params ... OK Setting bootloader params ... OK Writing BL 0 ... OK Writing BL 1 ... OK Writing BL 2 ... OK Writing MBR ... No ACK after write block command Operation failed |
04-28-2015, 21:21 | #3 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Charge fully battery aand try again I flash this phones about 100pcs without problem then vygis software working correct for sure. Drivers problem or battery not fully charged. |
