Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 01-29-2010, 12:40   #1 (permalink)
mobile-phone-service's Avatar
Member: 599385
Sonork: 100.1583205
LG GD510 Problem to conect via Test Point!
Hi support,
I try to conect the LG GD510 via Test Point but all time get this problem:
Please power ON phone
Loading primary loader ... OK
Loading secondary loader ... OK
Changing baudrate ...
Operation failed
Or
Changing baudrate ... OK
Setting bus ...
Operation failed
Any Ideas what can be wrong?
Thanks,
BR,
Old 01-29-2010, 18:51   #2 (permalink)
chimed09's Avatar
Member: 479816
press and hold power on...
Old 01-29-2010, 19:38   #3 (permalink)
Member: 599385
Sonork: 100.1583205
Yes i do always but same problem.....
Old 01-29-2010, 21:52   #4 (permalink)
Member: 288521
order lg gd510 cable from gpg and problem will be solved
The Following User Says Thank You to zubairhussain For This Useful Post:
Old 01-29-2010, 22:03   #5 (permalink)
DOUHAL's Avatar
Member: 43036
Sonork: 100.62160
LG GD510 supports USB connection only when phone is unlocked,if phone is locked - you can only flash phone.
For unlock code reading is needed to connect phone via
UART using TP on PCB.
Old 02-16-2010, 08:38   #6 (permalink)
Crumarix1's Avatar
Member: 84300
But for me worked USB reading code as well
Old 02-23-2010, 16:15   #7 (permalink)
Member: 847
how?
regards
Sjakie
Old 03-06-2010, 08:28   #8 (permalink)
Member: 1175471
I have the same problem, but I use GPG g510 Cable!
What is wrong?
Old 03-06-2010, 20:08   #9 (permalink)
Member: 572171
bro we done some off then with usb cable or with gw300 rj 45 cableots working with us 100 percent nothing happond try it and pls reply
Old 03-06-2010, 21:10   #10 (permalink)
Member: 474339
me too having same problem..with vygis. phone no responded error..help plz
Old 03-14-2010, 13:45   #11 (permalink)
saqibmalik's Avatar
Member: 294880
Sonork: 100.1587133
i have done this by connect phone via UART using TP on PCB.
Phone type : LG-GD510
Phone IMEI : 357248-03-4****4-0
Setting bus ... OK
Loading certificate ... OK
Reading phone info ... OK
Reading sim unlock code... OK
Sim unlock code : 2605808526667336
======== Process completed ========
Operation time - 00:01
For operation finishing,do next :
- power phone ON without SIM
- type 2945#*510# to enter unlock menu
- enter unlock code : 2605808526667336
The Following User Says Thank You to saqibmalik For This Useful Post:
Old 03-31-2010, 10:43   #12 (permalink)
Member: 7844
please explain what is UART . thanks
Old 03-31-2010, 10:52   #13 (permalink)
BVC-PROJECT's Avatar
Member: 45796
Universal asynchronous receiver/transmitter
Thats meen,you must use USB to Serial interface,any kinds,or clasic COM interface.
BR.
Old 03-31-2010, 17:05   #14 (permalink)
mobileZONE's Avatar
Member: 125401
gw300/rj45 cable works 4 me battery out then in n power on...
Old 04-08-2010, 18:50   #15 (permalink)
eky
Member: 46782
Can someone explain the procedure with the UART or the direct connection to the box, because I do not work, maybe a chart or explanation.
Lg U8360 Not Working After Unlock Via Test Point viru HWK 6 04-20-2011 19:08
How to unlock a phone via test point microsoule Motorola Hardware Repair Section 8 05-02-2006 09:13
unlocking via test point is good in cid49 SHANU Cruiser Suite 0 03-23-2006 18:45
how to unlock V3x via test point datalife2000 Smart-Clip 1 03-02-2006 20:59
How to Connect K750i Test Point & Where Is The Test Point Location MT_LBN Sony Ericsson 0 02-03-2006 00:24
Page generated in 1.19135 seconds with 11 queries
