Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 08-08-2011, 03:26   #1 (permalink)
gsmbacgiang's Avatar
Member: 1518666
Sonork: 100.1608201
Thanks Meter: 31
Post LG P509 T-mobile Unlock error please help
Connecting ... OK
Connected in EMERGENCY MODE
Writing flash from file : P509_V10_FOR_UNLOCK.crc
Checking flash files,please wait ... OK
TIME CRITICAL PROCESS
NOT MAKE ANY OTHER OPERATIONS WITH PC!
Writing PARTITION TABLE ... OK
BCPL STATUS : OFF
Writing AMSS ... OK
Writing APPS Boot ... OK
Writing BOOT IMAGE ... OK
Writing SYSTEM ...
Operation failed
Old 08-08-2011, 05:22   #2 (permalink)
nans1981's Avatar
Member: 629558
Thanks Meter: 53
try to other pc your problem solved.
Old 08-08-2011, 05:29   #3 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 160
Originally Posted by gsmbacgiang View Post
colleague only charge the battery while the phone and then try and see that will work for you, just be patient and see that will come out all right.
Old 08-08-2011, 10:32   #4 (permalink)
DOUHAL's Avatar
Member: 43036
Sonork: 100.62160
Thanks Meter: 2,386
Yes as writen on the message shownig on the software also DO NOT MAKE any Other operation in PC ( NOT disturb Your PC ) becaus needed full ram speed in this operation .
Douhal
Old 08-08-2011, 10:33   #5 (permalink)
Member: 1518666
Sonork: 100.1608201
Thanks Meter: 31
I tried Flash file on a computer other than the battery is full. But the result is the same.
My phone fell into suspension.
Can you help me solve this problem.
Thank you all
Old 08-08-2011, 10:44   #6 (permalink)
Member: 1518666
Sonork: 100.1608201
Thanks Meter: 31
Douhal
I will try again on a different computer configurations with more ads.
this is my current configuration to Flash using LG-P509:
Computer:
Inter (R)
Pentium (R) 4 CPU 2.40GHz
2.39GHz, 2:00 GB of RAM
It is not good enough to Flash P509 with Vygis?
Old 08-09-2011, 02:27   #7 (permalink)
Member: 1518666
Sonork: 100.1608201
Thanks Meter: 31
please help me.
First I put the phone into emergency mode:
for P500, P500h, P503, P509 - press and keep pressed "Volume up" + "Return" and connect USB cable to phone,
on LCD must appear, "Emergency mode"
Then connect the phone, start: LGQ_1_74SD and Vygis Flash File in support.
The result is a Flash device can not succeed and fail.
Vygis team please help me.
Thank you.
Old 08-09-2011, 12:09   #8 (permalink)
Member: 1518666
Sonork: 100.1608201
Thanks Meter: 31
Originally Posted by *******1276 View Post
hey men , do in the octopus, with the patch for unlock lg p500h.
hi,
I only use Vygis.
Old 08-09-2011, 13:42   #9 (permalink)
DOUHAL's Avatar
Member: 43036
Sonork: 100.62160
Thanks Meter: 2,386
charge full battry > change PC > use ltest version 1.90
ps : P500 and P503 flashes are not compatible with P500h - don't try to write them to P500h phone, because < phone will be dead >
The Following User Says Thank You to DOUHAL For This Useful Post:
Old 08-11-2011, 03:40   #10 (permalink)
Member: 1518666
Sonork: 100.1608201
Thanks Meter: 31
Question
I tried to flash P509 with a good battery, on a different PC I am sure it is good. But the result is the same. I always get an error message. I used version: 1.90
Vygis can help me.
Thanks all
Old 08-12-2011, 14:06   #11 (permalink)
chimed09's Avatar
Member: 479816
Thanks Meter: 851
Arrow
Vygis can help me.
Thanks all
what version for this phone??????????
Old 08-13-2011, 09:15   #12 (permalink)
Member: 1518666
Sonork: 100.1608201
Thanks Meter: 31
hi,
version for this phone:
Phone type selected : P509
IMEI : 354043-04-xxxxxxx
Bluetooth Addr : 64:99:5D:C4:F9:22
Phone version : P509-M76XX-V10l-OCT-23-2010-XX
Compilation info : Oct 23 201016:21:32Sep 02 201014:00:00P509
Old 08-13-2011, 17:31   #13 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Its wierd that ur getting same error in different computers...
Old 08-15-2011, 01:44   #14 (permalink)
Member: 1518666
Sonork: 100.1608201
Thanks Meter: 31
true,
I get the same error on a different computer.
You can help me solve the problem.
The computer I use a company computer dell: gx280, GX270 and Dell 745
Tests on three computers are getting together on an error.
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Page generated in 0.23450 seconds with 10 queries
