12-18-2010, 10:29 | #6 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 785041 Status: Offline Thanks Meter: 27 | its GS102 RJ-45 CABLE same wich you use to unlock T300 or you can unlock via micro usb cable Phone type : LG-T300 Phone IMEI : 353810-04-741446-6 Phone version : LGT300AT_V10a_226-01_OCT-01-2010 Connecting phone - connect USB cable to phone, phone must be OFF and without battery ... OK Opening USB Flash Port (COM5) ... OK ---------------------------------------------------------- Loading primary loader ... OK Loading secondary loader ... OK Loading certificate ... OK ---------------------------------------------------------- Reading phone info,please wait ... OK Reading sim unlock code... OK Found sim unlock codes : NCK : 3369 5040 6763 9763 NSCK : 7839 1623 6257 4911 SPCK : 9356 6573 2224 8102 CCK : 0563 3597 1944 6786 SIM : 1414 3638 8270 0772 ======== Process completed ======== Operation time - 00:00 ---------------------------------------------------------- For operation finishing,do next : - power phone ON - type 2945#*300# to enter unlock menu - enter needed unlock code |
12-21-2010, 05:42 | #7 (permalink) |
Junior Member Join Date: Oct 2008 Location: mean while in Tonga
Member: 877485 Status: Offline Sonork: daaas Thanks Meter: 6 | successfully unlock lg t320 by usb Phone type : LG-T320 Phone IMEI : 353813-04-060105-5 Connecting phone - connect USB cable to phone, phone must be OFF and without battery ... Driver connected, connecting phone ... OK ---------------------------------------------------------- Changing baudrate ... OK Setting bus ... OK Loading certificate ... OK ---------------------------------------------------------- Reading phone info ... OK ---------------------------------------------------------- Reading sim unlock code... OK Found sim unlock codes : NCK : 0234 4310 3653 8365 NSCK : 4848 0282 9768 7914 SPCK : 4492 7759 0369 4810 CCK : 8224 9889 2215 6921 SIM : 5795 2982 1817 2684 ======== Process completed ======== Operation time - 00:01 ---------------------------------------------------------- For operation finishing,do next : - power phone ON without SIM - type 2945#*320# to enter unlock menu - enter needed unlock code |
12-30-2010, 07:01 | #8 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 43
Member: 81445 Status: Offline Thanks Meter: 14 | brother which port?..........tick which one enumerate Ports and down the buttom change standart connection to usb \ plz give more detail coz i m having problems unlocking |
12-30-2010, 08:08 | #9 (permalink) |
Member: 785041 Status: Offline Thanks Meter: 27 | on port and settings tab select usb to rs232 by vigisoft ( you dont need to tick enumerate ports or autofind ports ) and in the conection options tab select usb conection you must have the latest usb drivers installed ( lg infineon agr last ) wich you find on the support area . and the software tells you what to do to unlock or read codes good luck |
03-23-2011, 06:41 | #13 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Mauritius ,Port Louis
Member: 528610 Status: Offline Thanks Meter: 4 | Attach USB cable now ... Phone detected; USB Port opened; Boot-loader Alive; Sending loaders; Done; Boot Mode: DD; Ebl_ver: NOT RELEASED 65535..65535; Sending loader config; Done; Flash ID is: 00AD:00BA Reading eeprom; Reading calibration; Saved: T320_T320e_T320q_T325_09.18.46_23.03.2011_EEP_CAL. bin UNLOCK CODES: NETWORK: 7905812678539063 NETWORK SUBSET: 9575626655371382 SERVICE PROV.: 2768016822713657 CORPORATE: 0932953446325756 SIM/USIM: 5297623988703115 Power on phone with accepted sim. Type 2945#*320# and enter code. Time needed - 00:00:23 unlock done in 5 second with furious gold |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
Sp unlocking sim - if you can get or sell please let me know | andrew bennett | Wanted Products | 1 | 09-24-1999 08:43 |
