04-04-2014, 01:39 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | LGA_1_25SD is released.New models for screen lock reset added. - added screen lock reset for next LG Android phones : LG E440,E440G,E440F,E440J,E445,E450,E450B,E450F,E450G ,E450J,E451G, E455,E455F,E455G,E460,E460F,E465F,E465G,E467F and E470F. |
The Following 13 Users Say Thank You to vygism For This Useful Post: |
05-25-2014, 00:52 | #5 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Corral de Bustos, Argentina
Member: 578880 Status: Offline Thanks Meter: 144 | LG E451g Unlock ( L7 ) Phone type : LG-E451G Phone IMEI A : 356304-05-12xxxx-x Phone IMEI B : 350305-26-000000-1 Phone BT address : CC:FA:00:5A:5E:52 Phone version : LGE451gAT-01-V10c-722-34-SEP-04-2013+0 Connecting phone - connect USB cable to phone, phone must be OFF - if you can't connect using micro USB cable - use P999 cable (with 910k resistor) ... Opening USB Port (COM19) ... OK ---------------------------------------------------------- Loading primary loader ... OK Executing loader ... OK Reading flash info ... OK ---------------------------------------------------------- Reading phone info,please wait ... OK ---------------------------------------------------------- Unlocking ... Making eeprom backup file ... OK Decrypting backup file ... OK Writing eeprom ... OK ======== Process completed ======== Operation time - 00:14 Thanks Vygism |
The Following User Says Thank You to nikita3000 For This Useful Post: |
12-31-2014, 04:04 | #10 (permalink) |
No Life Poster Join Date: Sep 2008 Location: The Land Of Promise
Member: 857401 Status: Offline Sonork: 1596086 Thanks Meter: 129 | icant find LGA_1_25SD in support where is the exact directory? ok i found Last edited by dabing; 12-31-2014 at 04:12. Reason: i found in directory |
09-12-2015, 05:29 | #12 (permalink) |
Freak Poster Join Date: May 2010
Member: 1302063 Status: Offline Thanks Meter: 4 | Connecting phone - connect USB cable to phone, phone must be OFF - if you can't connect using micro USB cable - use P999 cable (with 910k resistor) ... Opening USB Port (COM122) ... OK ---------------------------------------------------------- Loading primary loader ... OK Executing loader ... No ACK after PBL execute command Operation failed After unlocking it, need to repair imei but the failure message shows and phone switched to downloading mode. Anyone knows how to bypass it? |
