Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 08-09-2008, 14:43   #1 (permalink)
zeljko_c's Avatar
Member: 407770
A litlle techical help!
I buy this box and it`s very good for LG phone,but something not good, my box does not sync some phones for example KG800!
Old 08-09-2008, 20:57   #2 (permalink)
Member: 4458
What means doesn't sync KG800? Basically noone box syncs any phone
Regards,Vygis
Old 08-11-2008, 08:36   #3 (permalink)
zeljko_c's Avatar
Member: 407770
I mean not see some models KG800 and Qualcomm U8290 for example, I have correct cables for this models and box not see them!The Led lights blinking on box, but nothing`s happen!No boot!
Old 08-11-2008, 10:53   #4 (permalink)
Member: 4458
Can you describe problem - what version of software you was using,what phone tried to connect and with what cable.
Regards,Vygis
Old 08-11-2008, 15:13   #5 (permalink)
zeljko_c's Avatar
Member: 407770
@vygism
Yes of course!
The software is LG_1_91SC and I first trying to connect KG800,but no boot! The cable is KG800, wich I succesfully unlock LG KE970 with LG Infineon V1.36!
And U8290 with LGQUALCOMM 1.12 with U8110 cable!
In port settings is selected USB-RS232 by Vygisoft interface, box is switched on fbus!
I reading help from support area and I didn`t find anything to solve this problem!
Old 08-11-2008, 15:22   #6 (permalink)
Member: 4458
About KG800 - seems,that cable is OK,anyway if you can't connect-I would check phone's internal connector-as KG800 is supported long time ago and noone user reported problems about connecting.About U8290-use latest LGQ_1_24SC software for it and use USB cable.
Regards,Vygis
P.S.If you still want to use older LGQUALCOOM_1_12 sw for U8290 - you need LG7050 cable.Anyway I advice to use LGQ_1_24SC and USB cable.
Old 08-11-2008, 15:32   #7 (permalink)
zeljko_c's Avatar
Member: 407770
The cable for KG800 is correct, wich I was unlock and flash one KE970!
OK!Looks no problem!I check this out again, and I post the result, thanks for post!
rVolume Offer - which want share litlle arm reversing project ? - enter then :-) gsmVolume GSM Programming & Reverse Engineering 37 06-25-2005 18:36
Litlle explane Format1 Samsung Flashers, Software, Firmware. 0 03-02-2005 07:32
searching: Alcatel Techical zone calculator BF3!! --==Dixon==-- BF, BG, TH, BHx Series 14 10-04-2002 09:36
litlle gift :)) Dead Sagem solution KKK Infineon C16X M51 & ARM7 M52 BASED 5 10-08-2001 15:19
Page generated in 0.41232 seconds with 11 queries
