01-21-2006, 23:42 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Tinzawatine Age: 44
Member: 175273 Status: Offline Thanks Meter: 68 | @ Mr Gobi or Mr Vygis :How to write a GDFS in U8360 I have flashed It with a full flash but the phone still dead ! Can you tell me hoàw to write a GDFS in this phone please ? |
01-21-2006, 23:56 | #2 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Town City Age: 54
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | Quote:
Use TP under V1.20 and Follow the Process .The WRITE GDFS button will BE ACTIVE.Then you can easily write your gdfs.Without gdfs, your phone will try to BLINK only. | |
01-22-2006, 00:17 | #4 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | Quote:
U8360 Testpoint picture is avaiable on the support area. So --> select in the software 8360 TP Then flash, USINHG TESTPOINT, the U8360 FULL FLASH for repair, avaiable in the support area, then press relock / unlock. (with TP you will be able to do it) regards, Gobi | |
01-22-2006, 00:47 | #5 (permalink) |
Member: 175273 Status: Offline Thanks Meter: 68 | I have tried to do what you have said but when I have seen 8360 Tp It wasn't claer for me ! Here is the test point picture (from my phone mother card ) ! Can you help me ( slowly ) how to do this test point ! Where is the point to connect with GND ?? |
01-22-2006, 00:55 | #6 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | In your picture, the TP is under the black epoxy. It is somewhere where i have pointed with RED. You need to scratch the epoxy to clean access to this point. Then, when the software asks you, you connect this TP to GND. regards, Gobi Last edited by Gobi; 02-26-2007 at 21:36. |
01-22-2006, 11:54 | #7 (permalink) | |
Registered User Join Date: Aug 2003 Age: 41
Member: 36653 Status: Offline Thanks Meter: 336 | Quote:
to revive a 8360 I flashed it like U8380TP with full flash of 8360 | |
