Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 01-31-2006, 21:18   #1 (permalink)
faisal butt's Avatar
Member: 44167
Thanks Meter: 17
my o2 activation is not working
hi i habve buyed o2 activation but when i try to paste it into my pc it gives hardware key not found the resller took my dongle and he says that it was working onhis pc so what could be the reason pls help
Old 01-31-2006, 23:57   #2 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
I suppose we are talking about Smartcarddongles here.
Then, you just have to copy the reg file received from your reseller in same directory with the O2-BenQ software, and it should work.
One more possible cause can be: if you have SST software installed on that PC, try to uninstall the ROCKEY drivers in CONTROL PANEL --> ADD/REMOVE SOFTWARE
regards,
Gobi
Old 02-04-2006, 22:51   #3 (permalink)
Member: 44167
Thanks Meter: 17
plsn it is not working still not ok
pls i tried to uninstall my sst crack and even i instaled on a fresh system and i tried oon 4 pc but not working my reseller took my dongle and he says that it works but with me not working pls help i need it cause spent one month still not working or tell me what to do pls pls pls
Old 02-04-2006, 22:58   #4 (permalink)
Irinel's Avatar
Member: 4201
Thanks Meter: 6
Did you put the reg file(received from customer) in the same folder with software? (i mean software for Vitel Phones) ?
Best regards,
Irinel
Old 02-04-2006, 23:02   #5 (permalink)
Member: 44167
Thanks Meter: 17
yes i pasted the actvation file witht the 02 diffrent exe but it is gving hardware key not found well in the other sftwares the new dongle is wroking like sharp and new lg and sanyo and lg 3g i worked alot well thanx nay way for ur kind reply thanx but i m still and some times when i loose business but happy with other things of vygis thanx
Old 02-04-2006, 23:50   #6 (permalink)
Irinel's Avatar
Member: 4201
Thanks Meter: 6
OK but be carefull because the regfile from Alcatel / LG not working for O2 phones.
If you talk about - 02X1i - O2x1b - O2X3 + Ben: QM300, M550G,M555,M560G,S820C, S830C + O2X7 + O2X4 this is extra addon and you must pay for this.
If you talk about O2x7 this is Vitel addon and also you must pay for them.
Read here all of the info: http://www.vygistoolbox.com/#68
Best regards,
Irinel
Old 02-05-2006, 10:36   #7 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
It is getting missguiding.
Ok, we have 2 software activations (extra payed softwares) that supports O2X7 :
nr1: called O2-BenQ software
02X1i - O2X1B--BenQM300 AND NEW BENQ 550, 555 + O2X3 sw + o2x7- 170$
O2-Benq reg file looks like: regxx..xx_O2.dat(where xx..xx is your dongle id)
nr2: called Vitel software
Vitel TSM1,TSM2, TSM3,4,5,5m siTSM6 si Grundig M240 + O2X7 - 170$
Vitel reg file looks like: regxx..xx_TSM.dat(where xx..xx is your dongle id)
So, faisal butt - what activation do you have actually ?
Also, please PM me your dongle id, to check if you have smartcard dongle at all
regards,
Gobi
Old 02-06-2006, 00:17   #8 (permalink)
Member: 44167
Thanks Meter: 17
i have the 02 bnq activation
from ****** inpakistan from mr.abdul basit i took from his friend or reseller u can say mr sher ali he is my friend too he told me that he has checked this activation and dear sir now i m at home and when i will today go to my shop i will pm u my dongle id thanx for support thanx once again for fast reply
HELP MY Universal box is not working Unlock Dublin Universalbox 21 12-30-2008 11:45
My K500i's camera is not working??? amirbutt Sony Ericsson 0 04-02-2007 04:29
My 6630 now is not working....PLS HELP ME exxxpertul Nokia Base Band 5 ( BB-5 ) 0 02-04-2007 23:09
my furious com is not working??? falak FuriouS II 4 10-14-2005 06:57
my cloned griffin is not working any more after update?? infogsm Nokia Digital Core Technology 4 ( DCT-4 ) 2 03-18-2004 13:40
Page generated in 0.26695 seconds with 9 queries
