03-07-2007, 13:42 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 274214 Status: Offline Thanks Meter: 4 | My vygis box doesn't work with new version (LG) software My problem is that the box only works with software version LG_1_66SC. With newer version such as LG_1_72SC or LG_1_74SC, I can get the program up and running on the screen but it never be able to connect to a phone (after press Connect, phone booting never happens). Is there something wrong when I installing the software?,,,,the installation was quite simple though. Thanks in advance for your help. |
03-07-2007, 19:41 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | Hi.Strange problem and hard to say where is problem.Anyway is needed more info-your PC CPU,used OS system and also on what phones you tried to connect.Also bootloading starts or not? Or boot loads and later you have "Phone not respond".Also would be fine test software on other PC. Main difference between older versions and last LG versions - is used protector for software packing -Execryptor .Last LG software versions were protected with ExeCryptor v2.4 RC1 version,older with 2.3.9.Anyway future LG versions will be protected with v2.4 RC1,as it in principle must support Vista. Regards,Vygis |
03-07-2007, 22:31 | #3 (permalink) |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | I have the same problem but I can work when I use correct com port select but when I select vygis box I can't conect with phone after change to com port select in my case port 8 all work on what is problem and I have the same from 1.71 version or 1.72. bye |
03-07-2007, 23:24 | #4 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Subotica Age: 54
Member: 60687 Status: Offline Thanks Meter: 32 | this is very very good box (maybe one of five useable box),better you check your pc hardware configuration(baud rate,com settings...and other boxes software.some boxes phoenix, ustpro-2 dont working same time with vygis, or vygis is cannot start when connected this boxes on usb,you must close this programs or disconnect other boxes from usb and all be ok)! |
03-08-2007, 02:48 | #5 (permalink) |
Member: 4458 Status: Offline Thanks Meter: 25,853 | At first I would say to check installed drivers for box-almost all last softwares need new drivers - they also are called drivers for VPower box,you can download them from automatic support sites.Enter to them from anyone software-later goto "Support area root" and later select "Drivers" - "USB cable drivers". Regards,Vygis |
03-09-2007, 08:15 | #6 (permalink) | |
Member: 274214 Status: Offline Thanks Meter: 4 | Problem Solved Quote:
I have updated USB cable driver, everything goes OK now. | |
11-18-2007, 13:22 | #7 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Belarus
Member: 170408 Status: Offline Thanks Meter: 120 | LGI_1_24SC and other don t work on VISTA, protection card error.I can not understand why, as Infyniti, Setool, Scard dongle, Rocker dongle working good, use e-gate_V4.0.0.2_winvista drivers) |
Can not work with new version of JAF. | GSM-STUDENT | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-08-2010 17:13 |
It Doesn't Work With New Seus | yog1971 | KULANKENDI Server | 0 | 04-27-2007 21:19 |
Zxxx Series not working with new version | strangerboy | NSPRO | 2 | 08-04-2006 03:31 |
Zxxx Series not working with new version | pepgra | NSPRO | 22 | 07-31-2006 23:26 |
Zxxx Series not working with new version | strangerboy | NSPRO | 24 | 07-24-2006 12:23 |
