Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 08-16-2008, 21:26   #1 (permalink)
Cheater -Don't Deal with him-
.:GSM International:.'s Avatar
Member: 8879
Sonork: 100.84016
Need Help - U300
Hi all
I have tried to temp unlock U300, phone connected via usb ok, read phone as usual, selected file to flash, and then when i tried to write file, it errored after AMSS part, and said i needed to enter phone into Emergency Mode!
I've done that, and repeated procedure, but still, same thing happens!
Now phone is stuck on 3 logo when i try to power up, any help please?
Old 08-16-2008, 21:39   #2 (permalink)
Member: 4458
Check baterry at first-later check,if your phone is really U300,but not U300C-as U300C can't be flashed with U300 flash.
Regards,Vygis
Old 08-18-2008, 17:23   #3 (permalink)
Member: 8879
Sonork: 100.84016
It's definitely u300 mate, and a UK one!
But now, after successful flash, phone is locked to all networks!
How to fix?
Old 08-18-2008, 18:07   #4 (permalink)
Member: 4458
I guess,that you flashed phone in emergency mode after first unsuccessful try-in this case is needed to read "Flasher help.txt"-here is short quote from it :
"If flashing was not finished correctly do next :
- press "Disconnect PORT" at software
- disconnect phone from cable
- put off-put on baterry,power ON phone,connect cable and try connect
with software again
- if phone blinks or can't be connected in normal way-disconnect if from
software and cable,put off-put on baterry,press 2,5 and power ON buttons together
on phone's keyboard-phone must enter to "EMERGENCY" mode
- connect phone to cable,connect with software and write flash file
- after flash writing go to "Unlocker" section and press "Write NVM" for
phone's NVM backup writing.
- if phone's NVM backup was not created-use "Repair NVM" option"
basically is needed to restore your phone NVM-it must be in "NVM" folder.
Regards,Vygis
Old 08-18-2008, 22:05   #5 (permalink)
Member: 8879
Sonork: 100.84016
with software again
Regards,Vygis
Hi Vygis,
Ok, i have written back original NVM, phone still 'USIM Locked', have tried to repair NVM, still same.....
There must be a way to fix?
Old 08-18-2008, 22:15   #6 (permalink)
unlock trigger's Avatar
Member: 818352
Originally Posted by .:GSM International:. View Post
Hi Vygis,
Try this Procedure Posted Here:U300 still locked
Best Reagrds
Unlock Trigger
Old 08-18-2008, 22:25   #7 (permalink)
Member: 8879
Sonork: 100.84016
Best Reagrds
Unlock Trigger
Thanks for the link mate, but my prolbem is that now, after flash, handset is locked to ALL networks, including original!
I need fix asap!
Old 08-18-2008, 22:40   #8 (permalink)
Member: 818352
I need fix asap!
Strange Problem. I Think ur 3uk Sim card is Damaged Kindly Check it.if it is ok.
Then try to flash phone using LGMDP_H3G_SC
Make sure u Backup ur Nvm
U Can Download Software and flash files for unlock from here:
http://rapidshare.com/users/EQMSVG
Good luck!!!
Best Regrds
Unlock Trigger
Old 08-19-2008, 13:08   #9 (permalink)
Member: 8879
Sonork: 100.84016
Good luck!!!
Best Regrds
Unlock Trigger
Thanks anyway mate, but it is all done now!
REflashed on vygis, and this time it didnt error!
Old 08-22-2008, 07:58   #10 (permalink)
umadineshdas's Avatar
Member: 306096
Sonork: 100.1585877
bro
It can do parmenant unlock ya tempurary unlock? Ya doing also code ? please tell me bro?
umadineshdas
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP FuriouS TeaM FuriouS TeaM Products 66 08-27-2010 13:20
help needed in u300 unlock with ust-pro2 surajrasaq UST Pro II 0 07-19-2007 11:16
@Hack3r2k -----> Need Help Regarding U300.......! Moderate FuriouS TeaM Products 7 06-16-2007 15:27
Urgently Need Help On Lg U300 AbdulKadir UST Pro II 1 05-08-2007 16:18
need help from siriya to unlock u300 falak UST Pro II 0 11-29-2006 16:28
Page generated in 2.84897 seconds with 11 queries
