Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 02-27-2005, 09:26   #1 (permalink)
Member: 45477
Thanks Meter: 22
No connection with the box
here is a couple of questions to Mr Vygis
What is the VCC switch for?
F-bus/M-bus swtch?
I have a USB version of the box, what COM port should I choose.
None of the ports is working for me, the sw says "connect cable to the phone and press ON"
Thanks
Old 02-27-2005, 18:03   #2 (permalink)
Zoli's Avatar
Member: 46580
Thanks Meter: 3
F-bus/M-bus swtch?
Thanks
...open> ports & settings> USB-RS232 by Vygisoft...make sure you have drivers&proggy in same directory
no comment on VCC & F-bus/M-bus...
Zoli.
Old 02-28-2005, 05:44   #3 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
F-bus/M-bus swtch?
Thanks
Vcc Switch is for applying/or not Vcc voltage to the phone. Some phone need this voltage, some other don't.
F-bus/Mbus - sorry, but this i will not explain - this is to elementary; you have to learn to tu use search functions on the internet...
This switch has to be in Fbus position.
For Port - you have to choose USB-RS232 by Vygisoft
regards,
Gobi
Old 03-05-2005, 21:23   #4 (permalink)
Member: 45477
Thanks Meter: 22
sentinel drivers are installed, usb drivers are in the same directlory as the program.
Ports&Settings -> USB-RS232, speed 115200
When I hit connect, the error message is
Open_usb_device_by_device_description - Device not found
I tested it with 2 different phones. Can it be because the phones are not supported by this box?
Or something else?
Old 03-06-2005, 05:38   #5 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
You get this error because the driver for the USB Vygisbox is not installed.
When you connect the VygisBox to the USB port -- then the PC must detect it and some driver installation wizard will ask you for the location of the drivers.
Then you must point it to the location where this usb drivers are, and this drivers will be installed then.
regards,
Gobi
Old 03-06-2005, 05:59   #6 (permalink)
Member: 45477
Thanks Meter: 22
There was a dialog when I first connected the box, and I installed the drivers.
I have FTDI drivers installed for use with samsung usb cables, maybe that is a problem and they are conflicting in some way?
Old 03-09-2005, 08:13   #7 (permalink)
Member: 45477
Thanks Meter: 22
Reinstalling drivers didn't help. Any suggestions? Faulty box?I bought it from unlockcellular.com
Old 03-09-2005, 09:26   #8 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
Seems you need really some support from your reseller.
Contact them, they are nice guys and will help you ..
regards,
Gobi
please help I have no connection with the main support work zorom Infinity-Box 1 12-03-2009 17:04
LG KF900 can't connect with the box sunshinelin VygisToolbox 0 07-05-2009 21:52
No connection with the Box eletrico J.A.F. By Jafsupport.com 6 11-27-2008 10:58
Page generated in 0.16771 seconds with 10 queries
