06-10-2009, 22:07 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: colombia
Member: 735850 Status: Offline Thanks Meter: 15 | Please help lg ms25 ixxx I am trying to change IMEI lg ms25 I like all the preceding is the help to unlock the vygis. but when I finish the phone with me is an error (ILLEGAL USE) thanks for your help |
06-11-2009, 22:23 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | It means,that you are doing something wrong.All process is described in "Unlocker help.txt"-main idea is that if you want to change IMEI-you need to flash phone with "Erase EFS" option. Regards,Vygis |
06-13-2009, 00:05 | #4 (permalink) |
Member: 4458 Status: Offline Thanks Meter: 25,853 | Here is some info about MS25 IMEI changing: 2c.KS20,MS20 and MS25 IMEI changing : - enter phone to "Emergency download mode" - for this press "Send(Call)" + "Function" + "Power ON" - LED in upper right corner of phone must turn to green - LCD display must be black - start software,connect USB cable to phone - press "Connect Port" and "Connect Phone" - phone must connects in emergency mode - go to "Flasher" section and select "KS20_V10b_S_3_1_1_00215_DIAG OK_ROM_FRENCH" flash file - "Erase EFS" must be checked,it is important - press "Write files & Do Jobs" and wait for process finishing - after flashing do next : - type 2676625720# to enter engineering menu - select Port Setting > 1. Diag Setting > 1. USB Set for Diag > "OK" > "Back" - select (Port Setting > 1. Diag Setting >) 2. USB Switching > "LG Composite -DUN, DIAG" - press Done and restart phone - connect phone in normal mode and in IMEI window write your needed IMEI - press "Repair NVM" and wait for process completing - again enter to emergency mode and flash your needed KS20,MS20 or MS25 ROM flash file in same way like was described before. Check if you doing everything like described before-MS25 IMEI changing is tested many time,so by me-you doing something wrong. Regards,Vygis |
The Following User Says Thank You to vygism For This Useful Post: |
06-18-2009, 23:07 | #10 (permalink) |
Member: 4458 Status: Offline Thanks Meter: 25,853 | Sorry-not catched-so DIAG_ROM was flashed with "Erase EFS" checked or no? Regards,Vygis P.S.If was flashed with checked "Erase EFS" and you still have "Unavailable OTP block"-do next-write KS20 full repair flash with checked "Erase EFS",after this change IMEI-after this write your Colombia flash. Regards,Vygis |
Please help!!! Lg tu515 v10f from rogers dead trying flashing, please help | ligasa | LG | 0 | 10-31-2008 23:02 |
please help lg c3300 | oskargsm | LG | 1 | 05-23-2006 14:22 |
please help lg c3300 unlock | obioha | powerflasher | 1 | 05-11-2005 04:46 |
Please Help LG G4015 | LANwiz666 | Phone Unlocking Codes & Maps | 3 | 09-19-2004 19:14 |
Please please help! LG 4050... please | blastywindy | LG | 1 | 03-07-2004 22:36 |
