Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 05-30-2008, 03:02   #1 (permalink)
Member: 689942
Problem in flash ke990 the operator Claro ( Brazil )
I'm trying to make a flash in a ke990 operator CLARO in Brazil. All 4 of the files I do support a flash, but when they turn on the unit get " unvailable wallpaper file. "
I can try to flash using a flash of KU990?
tHANKS ADVANCED
Old 05-30-2008, 16:31   #2 (permalink)
Member: 4458
Yes,you can try to write KU990 flash files.Main problem here,that flash changing won't help to unlock phone-and other problem is,that I still can't get this Claro original flash - this would fix this "unavailable wallpaper file" problem.
Regards,Vygis
Old 06-01-2008, 03:47   #3 (permalink)
Member: 689942
Indeed the cell linked with a flash of ku990c, but I am unable to unlock the software and vygis not have the option "read flash" so you can send a flash operator CLARO .
Old 06-02-2008, 01:10   #4 (permalink)
Member: 4458
Seems,that we can forget about new KE990 versions unlocking.Also is impossible to read something from Qualcomm based LG-they not allows own boots uploading to phone.But my main problem is,that I still can't get this Claro original factory flash.
Regards,Vygis
Old 07-30-2008, 22:54   #5 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
somebody share flash files for ku990 please
thanx
Old 07-31-2008, 17:05   #6 (permalink)
Member: 93339
VYGISM You must sticky that is unsafe to flash KE990 or KU990 phones with different flash file, because if you don't get the original flash, the phone will be dead for ever, i killed a Movistar KE990 from Argentina, i can recover it because you have movistar colombia flash on support and the wallpaper is the same... but for other phones will be a great problem, KE990 is very expensive
Old 08-01-2008, 09:45   #7 (permalink)
Member: 4458
OK,thx for idea-we will make such sticky-basically problem is only with Brasil Claro flash,as impossible to get it-it even can't be found on LG service site.
Regards,Vygis
Old 08-02-2008, 15:42   #8 (permalink)
Member: 147972
ke990_claro
Regards,Vygis
Hi Mr.Vygism, I have the original flash ke990 claro, if you want I can send the link for you.
regards, tectec
Old 08-06-2008, 14:45   #9 (permalink)
Member: 4458
KE990c Claro Brasil original flash,converted to .crc format is uploaded to support sites.Big thx goes for tectec for it.
Regards,Vygis
problem fo flash ke990 jam_mobile LG 1 12-26-2009 12:26
nokia n70 The problem in Flash mosbah100 Nokia Hardware & Hardware-Repair Area 2 12-11-2007 03:47
Probleme in flashing with the new version 10.15 MDK23 SMTi 1 11-24-2007 16:14
Z530i error of configuration enters in contact with the operator binhorp Sony Ericsson 7 12-16-2006 12:31
problem in flashing 6600 phone with ufs (start-up failed. contact the retailer) grapher Nokia Multimedia 9 05-29-2005 08:31
Page generated in 0.32448 seconds with 11 queries
